Go to Post and don't overestimate the ability of an unskilled fool with exotic tools! - MissInformation [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
  #91   Spotlight this post!
Unread 07-01-2006, 22:53
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
Re: ***THE GAME OFFICIAL: AIM HIGH***
I have a specific question. It states in this rule:
<G13> Balls Contained in ROBOTs at the Start of a match - Each ALLIANCE will start a match with 40 balls.
Each ROBOT may contain up to 10 balls at the start of a match. Any balls not contained within the robot
will be evenly distributed between the alliance ball corrals. All of the balls must be contained within the
ROBOT’s 28” x 38” x 60” starting volume and must be clearly visible from outside the ROBOT. The
Head Referee will require that balls outside of the starting volume be removed. It is the responsibility of
the head referee to verify that this rule is satisfied prior to the start of the match.
So do they have to be totally visible, from all angles, which sounds a bit unreasonable, or should the referee just be able to see each ball from some point outside of the robot, and if that is so, what happens if because a bunch of balls are stacked together, a ball is hidden by other balls, and is thus not visible to the referee? Is there a penalty for that, I can't find a penalty for failing to comply with this rule, so what exactly would they do in that situation.
  #92   Spotlight this post!
Unread 07-01-2006, 23:10
George A.'s Avatar
George A. George A. is offline
I come through in a spinsch
AKA: George- The Voice
FRC #0303 (TEST Team)
George A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond repute
Send a message via AIM to George A.
I don't think that it will be penalized when 10 balls are piled in...you obviously can't see through the balls...or it could be one of these "up to the discretion of the referee" deals...in which case they should have a set guideline to go by so there isn't the confusion like there was last year.
My Volunteer Resumé
Game Announcer NJ: 2005-Present
Game Announcer Philly: 2006-Present
Game Announcer NY: 2005-2008
Game Announcer Champsionships: 2005-2008
  #93   Spotlight this post!
Unread 07-01-2006, 23:13
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
That is a good question, I would bring it up with Q&A and wait for their response. I would assume that they just want to make sure that before the 10 balls are loaded, the robot does not already contain extra balls for cheating purposes. So as long as the refs can easily see nothing is in the robot before and after matches, you should not have a problem. This is only an assumption, I would still contact Q&A about this.
GO 1403 and GOOD LUCK TO ALL 2006 FRC TEAMS!!!
Team 1403 is Proudly Sponsored By:
  #94   Spotlight this post!
Unread 07-01-2006, 23:19
PARhodes's Avatar
PARhodes PARhodes is offline
FRC #1559 (Devil Tech)
PARhodes has a little shameless behaviour in the past
Just design for the rule. If the ref cant see them, like you said its up to their discretion, but i wouldnt take the chance.
  #95   Spotlight this post!
Unread 07-01-2006, 23:30
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
3.4.3 Ball CorralsA Ball Corral is located at the ends of the Alliance Station Wall to restrain any balls that enter through the Corner Goals. The Ball Corral covers a four-by-four foot area. The side walls of the Ball Corral are three feet tall and constructed of square aluminum tube and polycarbonate. The back wall of the Ball Corral is of similar construction, except it is only 20 inches tall to permit easy retrieval of balls from the interior of the corral.
<G39>Scoring Inerference - HUMAN PLAYERs, DRIVERs, or COACHes may not reach into a ball chute or in any way interfere with the ball counting system. Violations of this rule will result in DQ.
I'm I misinterpreting, or do these statements contradict each other?
  #96   Spotlight this post!
Unread 07-01-2006, 23:46
PARhodes's Avatar
I think there are designated makrs on the ball chorals which would be "roped off". Just dont reach into there which would interefere play. But you need to pick the balls out.
  #97   Spotlight this post!
Unread 07-01-2006, 23:48
netman85am204 netman85am204 is offline
AKA: Matt materniak
FRC #0204 (ERV)
netman85am204 is an unknown quantity at this point
Originally Posted by whakojacko
4.3.1<SO2> No ROBOT my throw a ball with an exit velocity of greater than 12 m/s (28.6 mph). [...] A Robot that violates this rule will be considered unsafe as per <S01>
I am believing that the velocity speed limit (12 m/s or 28.6 mph) would be the fastest the ball could travel through the center goal to actually be counted as a score by the automatic counting mechanism for their alliance.
-matt
  #98   Spotlight this post!
Unread 08-01-2006, 00:06
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
-matt
Actually, im guessing this is a true safety issue. Somewhere else in the rules it discusses that the speed limit ends up equaling a 30deg shot that goes 35'. Any farther than that and you risk shooting it into the audience.
Also keep in mind a ball is NOT Scored when it first enters the goal, its only after it goes down the chute.
  #99   Spotlight this post!
Unread 08-01-2006, 02:04
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
No.
The ball chute is the drop for the center goal and the ball corral is for the two corner goals. You may not interfere with the ball counting system for either.
-matt
This is incorrect. Per <S02>, the velocity at which the ball exits the muzzle(your robot) may not excede 12 m/s. This is considered in violation of <S01>, 10 point penatly and disabled for the remainder of the match.
Originally Posted by <S02>
Muzzle Velocity - No ROBOT may throw a ball with an exit velocity of greater than 12 m/s (26.8 mph). As a reference, a ball traveling at this velocity when leaving the ROBOT at an angle of 30ş from horizontal with no spin will travel approximately 35 feet. A robot that violates this rule will be considered unsafe per <S01>.
Does anyone know if a human player picking up a ball from the corral happens to drop it across the counting system, will the other team get a point?
Wetzel
Viva Olancho!
  #100   Spotlight this post!
Unread 08-01-2006, 02:53
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Wetzel
Let's put it this way - do you think the refs or the scoring system will be able to tell the difference between you dropping one over the ball counter or it being scoring by the opponent? Probably not. Since the scoring is automatic and immediate and sensor driven, I'm about 99.9% sure they are not going to take those points off because you have butterfingers (not you personally ).
However, realize there are times of the game where that scoring side will not be "active" so nothing can be scored on that side. So just drop it then and you won't have problems.
Also, regarding netting around the field - I was told it's been discussed and probably will be discussed more. Hopefully we get a decision on it prior to week 1.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
  #101   Spotlight this post!
Unread 08-01-2006, 03:41
Petey's Avatar
Petey Petey is offline
Strategy &amp; Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Wetzel, my guess is that you're correct--or they may call an "interference" penalty for "interfering with the ball counting mechanism."
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
  #102   Spotlight this post!
Unread 08-01-2006, 04:00
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Wetzel
The ball corral's are quite deep, and the light bar for the counter system is almost all the way in the back (from the HP's perspective), so while possible, the ramps may be steep enough that a dropped ball will fall below the light bar, and bounce to the bottom, thus not interfering at all.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
  #103   Spotlight this post!
Unread 08-01-2006, 04:13
AmyPrib's Avatar
Is it really an interference though? You'd be helping the opponent. They talk about reaching into the ball chute to interfere with it, but not really the corral. Besides, how do they assume an interference (intentional implied) if a ball slips out of your hand onto the lighted panel, or if you have so many in there, one bounces enough back up the inside ramp over the panel again?
How about this question?
- Is it legal to score for your opponent (since it's encouraged) by dropping the ball on the lighted panel?
I suppose No. Reading G05 again, it says once a ball is scored for an alliance, it cannot score again until it's re-entered on the field.
So the real question might be - how do they prohibit or rather, assess an accidental droppage or roll of a ball that might get counted on the light panel again while still in the corral? I don't see a penalty (besides interference) for that kind of thing on the HP or a means to subtract those points. DQ for interference call in this case seems harsh for a true accident. Good one for the Q/A!!
I guess I sorta take back my initial thought 2 posts ago.
  #104   Spotlight this post!
Unread 08-01-2006, 12:01
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
My team has a question....
Before game play, in the beginning, does each team in the alliance have a choice on placement on the field? like on red side, middle, or blue side? or is it at random??
thanks.
  #105   Spotlight this post!
Unread 08-01-2006, 12:49
Wetzel's Avatar
DC Robotics
thanks.
Originally Posted by <G10>
Starting Positions - At the beginning of a match, the three alliance ROBOTs must be placed inside one of the three 5’ x 5’ robot starting zones located at mid-field to the right of the DRIVER’s station and not
touching the tape boundaries. It is the responsibility of the head referee to verify that this rule is satisfied prior to the start of the match. The match will not be started until all robots are in the starting position.
Emphasis mine. They have left it up to the alliance to figure out who goes where.
Wetzel
Viva Olancho!
Video Game game. Eria4044 Games/Trivia 168 01-06-2006 10:11
We Aim For The Stars Part III Ken Leung General Forum 5 03-01-2006 16:57
"Gyrating Jamboree" game Mike Ciance Chit-Chat 7 26-05-2004 09:35
crazy game Mike Ciance Fantasy FIRST 22 25-05-2004 11:37
i didnt like this years game....please read archiver 2001 19 24-06-2002 03:23
