Problem installing Labview
I have all four of the cds and when I tried to install Labview app onto my laptop the c.d. doesn't show up. I tried this with the other two cds and there was the same problem. I then put each one in my mac and it showed up("
tells you something") Does any one else have this problem? |
Re: Problem installing Labview
Try a CD that you know has worked in the past in you computer. It sounds like you have an OS/hardware computer problem. LabVIEW is ran on windows most of the time, so it should work fine.
If you cannot get the PC version of LabVIEW to work on another PC with the same OS, send an e-mail to frc@ni.com and we can provide you with a link to download the PC version of LabVIEW off the web. As suggested by EagleMaster, your CD drive on your laptop might not be completely functional...
-Danny |
Suprisingly, we had the same problem with our labview CD. I just put it in my laptop and installed over the network. It must just be pressed in a way that picky drives don't read it.
| National Instruments LabVIEW and Data Acquisition Forum | Danny Diaz | National Instruments LabVIEW and Data Acquisition | 1 | 16-01-2006 13:20 |
| Need a realistic Statics Problem | sanddrag | Technical Discussion | 10 | 05-12-2005 15:07 |
| Programming Problem: Extremely Frustrating | chantilly_team | Programming | 19 | 12-02-2005 23:00 |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
| Major problem with chipphua motors | aka Scott White | Motors | 18 | 19-03-2002 19:44 |
