Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 08-01-2006, 14:47
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: R71: Can't re-use code that you've written before?
AND a retype of Kevin Watson's code. I mean, unless they further their attempt to be fair and make him a COTS vendor. Fair market value: $0.00.
I'm thinking if I change a line or two, then I have modified the code to be used for this game. I think if they are trying to make rules the same between programmers and mechanical engineers, then they have to introduce the other "mechanical" rules to allow everything to balance out and make sense.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
