Go to Post You people are online way too early in the morning... - Beth Sweet [more]
Unread 08-01-2006, 15:24
blue_crew blue_crew is offline
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
FRC #1323 (Madtown Robotics)
blue_crew is on a distinguished road
Send a message via AIM to blue_crew Send a message via MSN to blue_crew Send a message via Yahoo to blue_crew
Re: autonmous corner or center
i read there is a white light that is used to score the balls in the corner goals. would it be possible to track the corner goals using the camera?
I am asking because using dead reckoning to find the corner goals might prove to be difficult.
Unread 08-01-2006, 15:25
Ashley Christine's Avatar
Ashley Christine Ashley Christine is offline
FRC #1511
Ashley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond repute
I think that with the cameras, there is potential for chaos during autonomous.
But, I guess it will all work out in some way
Unread 08-01-2006, 15:43
Best Available Data
FRC #1778 (Chill Out!)
The corner goals are litterally right in front of you if you point your robot down field. Just point your and go forward. What's so difficult?
PS The camera won't track the corner goals, trust me.
PPS Listen to Tom, he's a bright guy.
Unread 08-01-2006, 16:04
Billfred's Avatar
Billfred Billfred is offline
Originally Posted by Nuttyman54
Well, atleast seeing the center goal will be easier. My only concern is that both light arrays are the same color, so if a robot gets turned around, it could score in the OTHER goal. So far, GDC hasn't told us what happens when a robot scores in the wrong goal during auto
My (entirely unofficial) interpretation of that: Balls are balls. If you hit their goal, they score points. Done deal.
Unread 08-01-2006, 16:10
Andrew Blair's Avatar
FRC #0306 (CRT)
Considering that many teams will use them for center goal shots, theres a potential for chaos during every period...
-Sir Francis Bacon
-Albert Einstein
Unread 08-01-2006, 16:55
FRC #1511
Very true, but humans will have a little more control, I see in autonomous all the bots going to similar or the same places trying to find the green, possibly quite a bit of collision. I guess that is where the bumpers come in!
Unread 08-01-2006, 16:58
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
It depends on what your robot is good at. If you have no mechanism for shooting, you won't try for the center. Our group has decided to focus on the corner goals, both in autonomous and in normal play.
Unread 08-01-2006, 17:09
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
All I know is that last year in Philadelphi, our camera locked dead onto MOE (Team 365) and their flourescent green shirts during the matches. They might want to consider what would happen if they get pelted with balls during the autonomous period!
Unread 08-01-2006, 17:13
FRC #1511
LMAO! That would be kinda funny, other then the not safe part. But yeah!
Unread 08-01-2006, 18:05
psquared89's Avatar
psquared89 psquared89 is offline
AKA: Pat Pannuto
FRC #0245 (Adambots)
Team Role: Driver
psquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the rough
So if you have a robot that shoots straight foreward, you just aim your robot at the high goal before the match starts, and then start shooting right when auto mode begins. As long as you've spent an hour or two ahead of time to make sure your robot shoots its balls at the right speed and angle, you don't have to worry about aiming...
Be careful about aiming your robot. There's a rule against using "any measuring devices while placing your robot that are not a permanant part of the robot", last year I used my shoe (it's exactly 12"), but I suspect this year that won't be allowed. If the ref decides you've lined your robot up against this rule, he's free to move/turn it at his discretion.
At the end of the game, the King and the Pawn both go back into the same box.
~ Italian Proverb
adambots.com
Unread 08-01-2006, 18:22
Davx's Avatar
Davx Davx is offline
Davux
AKA: Dave Amenta
FRC #0195 (Cyber Knights)
Davx will become famous soon enoughDavx will become famous soon enough
Send a message via AIM to Davx Send a message via MSN to Davx
Both goals being on the field should not be much of a problem, since it is unlikely that you will be pushed onto the wrong side of the field, and your robot will know what position it is starting in.
The green targets are roughly 10ft above the field, and if you are using Kevin's 2006 CMUCam code, you will be able to easily get the angle of your tilt servo, that angle becomes theta, from that you can do Tan(Theta) = (10/X) and solve for X. That reduces to X = (10 / Tan(Theta)). The field is 54' long, if you are >28ft away, you know that you are shooting onto the other side of the field.
It's not perfect, but it's unlikely that your robot will be pushed onto the wrong side of the field, and turned around. This is why it makes sense to have an onboard navigation system.
I’d really like to see our team design a bot capable of shooting into the center goal, the only real issue I can see is the hardware shooting device not being consistent enough to depend on it.
Unread 08-01-2006, 18:59
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
While at kickoff I asked Woodie if there were any concerns about missed shots at the center goal hitting the operators or the controls. He handed me a ball and told me to throw it at him as hard as I could... How many times does an opportunity like that come up?
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 08-01-2006, 19:30
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
The camera is absolutely esential to this game during both auton and manual mode. Thats the only way to constally keep track of the goal. Otherwise you would have to stop and postion the launcher so the ball goes into the hole. Think of doing this manually form over 30 ft away toward the other end away form you?
Realtime trig and projectile motion calculations!!!
Unread 08-01-2006, 21:07
dan da' geekman's Avatar
dan da' geekman dan da' geekman is offline
FRC #0281
dan da' geekman is an unknown quantity at this point
Yes, the camara would be nice to use in the manual 2 minutes, but then you are relying totally on the camara. our team was thinking of something where the camara would give some kind of feedback, whether or not the position of the "cannon" would make the shot.
Unread 08-01-2006, 21:29
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Center goal. All 10 in less then the 10 seconds.
I just don't know how to do it yet.
Wetzel
Viva Olancho!
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Pre-Shipping Scrimmage at the North Montco Technical Career Center OZ_341 Off-Season Events 1 05-02-2004 23:59
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
KSC Results archiver 2000 2 23-06-2002 22:19
