Go to Post For a good time, call 1-800-GOFIRST - Wayne Doenges [more]
Unread 08-01-2006, 15:28
fightoplankton's Avatar
fightoplankton fightoplankton is offline
Web Designer
AKA: Paul Shapiro
FRC #0555 (Montclair Robotics)
Team Role: Webmaster
fightoplankton is on a distinguished road
Send a message via AIM to fightoplankton Send a message via MSN to fightoplankton Send a message via Yahoo to fightoplankton
Omni-Wheel Design
Has any team come up with an omni-wheel design that allows for the mini-wheels in each omni wheel to turn on their own?
Unread 08-01-2006, 15:58
Seekthematrix Seekthematrix is offline
FRC #1257
Seekthematrix can only hope to improve
Re: Omni-Wheel Design
Can you explain further what you mean by each of the mini-whells turning on their own. My team 1257 had a functional holonomic drive using the omni-wheels last year the mini-wheels spin on their own based on the movement of the robot. Please elaborate on your question and im sure i can help you out.
P.S i hope you dont have in mine an omni-whell design for this years competition i wouldnt recomend it
Unread 08-01-2006, 16:10
Web Designer
AKA: Paul Shapiro
sorry. what i mean is that the omnis are not positioned like this
or any similar designs. I want to know if you can get the mini-wheels moving by motor or some other means.
Unread 08-01-2006, 16:27
FRC #1257
yea for the holonomic drive the wheels are position at 45 degree angles like this
/ \ I cant understand a practical reason for controling the miniwheels
\ / on a motor?
Unread 08-01-2006, 16:28
Web Designer
AKA: Paul Shapiro
there is...i can assure you
Unread 08-01-2006, 16:52
FRC #1257
one, i dont think its possible, two the prograaming would be ridicoulously complex to make it all those wheels actually being controlled by motors.
Unread 08-01-2006, 18:14
Web Designer
AKA: Paul Shapiro
i figured it out...using gears
Unread 08-01-2006, 23:49
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Sure its possible, but it would be overcomplicated, require very big wheels or very small gears.
The reasons I could see for this would be so be able to more easily climb the ramp, and have more pushing power in the forward direction.
I think you talking about positioning the wheels like this.
with the rollers opposite. Is this correct?
Also the programing for this would be no more complicated than the pro gaming for a normal omni drive. However I don't see the benefit of this over using a swerve drive because its more complicated to build and doesn't hold any advantages over a swerve.
Alex
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
Wheel Layout/Attachment Design Andrew Blair Technical Discussion 3 12-10-2005 19:29
new wheel design mechanicalbrain Technical Discussion 20 29-06-2005 14:13
Omni wheel supplier JamesBrown Technical Discussion 5 25-02-2005 13:27
pic: Team 60 Wheel Design CD47-Bot Extra Discussion 6 18-11-2004 19:57
