Go to Post Sleep?! How am I supposed to do that with the build season done?! There are still practice bots to make! - [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-01-2006, 18:39
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Green Light Power Source
We went to build our green light that goes above center goal. We could not figure out how to power it. Does anyone know how it is to be powered? I know this should go on First site, but no one knows where the password for their site is. I was hoping to get a faster answer here.
Thanx
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 08-01-2006, 18:43
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Green Light
As I recall their are green cold cathode tubes in the KOP, or are you asking how to power those? Their is also a included inverter, make sure you use it and don't try powering the tubes directly.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 08-01-2006, 18:45
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Green Light
Connect it to a 12V power source. If you can find one anywhere, you might try to look for a 12V battery - that would probably work (hint, hint )
Unread 08-01-2006, 18:54
Billfred's Avatar
Billfred Billfred is offline
Re: Green Light
Probably a slightly silly question, but will the fact that our 12V batteries are often slightly more than 12V negatively affect the lights?
Unread 08-01-2006, 18:55
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Green Light
Worth noting: The 8 cathodes and a small fan will require more than 1 amp to power. Our team has a 1 amp power supply that we hooked up to it, but it was only able to power the system at 8 volts.
I need to find where we put our spare Anderson hookup...
Unread 08-01-2006, 18:57
Re: Green Light
Yes they will be slightly brighter. From playing with moding computers I can tell you the voltage difference in the battery won't do much. I would using a AC to DC 12 volt converter though.
Unread 08-01-2006, 23:13
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Re: Green Light
An old computer supply makes a nice and cheap 12v power supply.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 08-01-2006, 23:40
Re: Green Light
That it does! For those interested take a look at this thread. http://www.chiefdelphi.com/forums/sh...ad.php?t=39754
Careful though you can make lots of magic smoke doing this wrong. You essentially short a specific wire, and shorting the wrong wire can be very bad.
Unread 09-01-2006, 00:10
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Green Light
Cool, a wireless field you can setup anywhere! Battery +field = field anyway!
I like this idea of a green LIGHT, it's a nice idea.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 09-01-2006, 00:48
Umm Errr...
Re: Green Light
The last few years, we have had CCFL's very similar to the ones used for the vision target on our robot. The brightness is effected slightly by input voltage, but not too much until the battery gets really low.
1139 Alumni
Unread 09-01-2006, 06:15
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Green Light Power Source
I'm assuming they included all the parts that normally come with a cold cathode tube kit, in which you could just hook it up to any computer with extra power connectors, or even just plug it into a power supply.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 09-01-2006, 07:31
Thanx
Bob,
Did you finally get it going? By now you may have put two and two together and found the power suppplies for the lamps. I think that was what you were asking. If you still have a problem, let me know.
Unread 09-01-2006, 07:59
BobC's Avatar
Big Daddy
Originally Posted by Al Skierkiewicz
Bob,
Thanks for everyone's help. Unfortunately I have left for vacation and won't know until I get back. I have passed the info on before I left so they will be able to finish them.
Bob
Unread 09-01-2006, 11:55
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: Green Light
wait a minute...
Dave posted a hint here yesterday. but no one has tried to analyze it word by word.
has something changed since the kickoff???
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 11-01-2006, 09:19
pheNIX637 pheNIX637 is offline
None #0637
pheNIX637 will become famous soon enough
yea i think if you use an old PS from a computer it would work. but i think u have to get a paperclip and stick the end in to 2 sprocket on the main feed from the power supply .. you have to do this because then the power supply is "fooled" by saying that there is a motherboard in place but really there isnt.. just google search it.. you will find it.
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
program light blinks red and green JBabbie Programming 3 02-03-2004 09:19
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
