Go to Post Magic doesn't count as a support, sorry. Neither does simply constraining in CAD... - EricH [more]
Unread 08-01-2006, 08:23
Dakota Snow's Avatar
Dakota Snow Dakota Snow is offline
FRC #0957 (WATSON)
Dakota Snow is an unknown quantity at this point
best way to score in the lower goals ??
I have been trying to figure out the best way to score in the lower goals. There is a ramp there in front of the goal So roling wound be trickly. Any one got some suggestions?
Unread 08-01-2006, 08:49
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: best way to score in the lower goals ??
Personally, I would do rolling. Just design a flexible/jointed pusher which can go up the ramp a little ways to get the ball over the hump. (or close with some force)
Unread 08-01-2006, 08:50
Davie Byrne's Avatar
Davie Byrne Davie Byrne is offline
Zork
FRC #1980 (The Brigade)
Davie Byrne is an unknown quantity at this point
Question Okay i've got a problem with the lower goals
I can't seem to figure out how to get around this. If a robot just sits infront of a corner goal (Which it easily can), and anothr robot can't move it without latching on how is anybody going to score in the corner goals. Are there any loopholes to get around this?
Unread 08-01-2006, 08:57
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Okay i've got a problem with the lower goals
Well, I guess you just have to beat them up until you can get in there. Theres going to be alot of contact this year around those goals, no way around it.
-Sir Francis Bacon
-Albert Einstein
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
I have merged the two thread together as they both ask the question concern scoring balls in the lower goals.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 08-01-2006, 16:11
Seekthematrix Seekthematrix is offline
FRC #1257
Seekthematrix can only hope to improve
that is why the defensive offensive alliance has the 3v2 thing with the robot staying back. There is only two robots defending. If a robot on defense just sits in front of the lower goal the 3 offensive robots have the ohter lower goal and the center goal. With only two robots on defense it isnt that benifical to sit in front of hte goal unless someone is immediatly at that time trying to score on a lower goal. Also that is the same visevera if an offesneive robot is infront of the lower goal feeding balls into score its pretty hard from teh defensive robot to defend other then ramming the robot
Unread 08-01-2006, 16:41
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
If the robot sits infront of the goal its not doing anything else, including getting in the way of the other two robots on the offensive. The only way i could see that strategy working would be if none of the robots on the offensive alliance could score on the center goal. then the two defensive robots would be able to block the only two places the offence has to score.
Unread 08-01-2006, 16:51
Best Available Data
FRC #1778 (Chill Out!)
A strategy of blocking the lower goals, while it will work in the early regionals during qualification matches, is not the best idea. Think about it, if you want to rank high, you must win often, by a small margin, in a high scoring match.
Relating to what Billfred said:
Last year's game lent itself to being total chaos, where you didn't care what your opponent scores. Since the RTS will actually be RT this year and the final ball score, you may will probably have time to say "Oh Gee! It's 75 to 15 and one of thier robots can't make it up on the ramp! Let's make thier score closer to ours!" and you'll have time to execute it.
This made me realize something: Will we get more matches as the refs won't have to score the object, merely see if your robot is on the ramp?
Unread 08-01-2006, 17:24
Billfred's Avatar
Billfred Billfred is offline
Am I the only person that doesn't even worry about RPs while on the field? I mean, with all the madness on the field last year, I had fifteen other things going on when I had field coach duty. Making sure we didn't beat anyone by too much just was down on the list.
Perhaps this season's game will allow for teams to keep more aware of the game status, allowing for more control over this. (Memo to self: make sure to ask the video guys to keep the RTS posted.)
Unread 08-01-2006, 18:56
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
While I don't think RP's are top priority in getting ranked high, it's still important.
First, you have to WIN your matches to be in the lead. Then, when you're tiered by that, if there's numerous undefeated teams (or teams with equal # of wins), you get ranked by your RP's.
There's a lot to think about on the field, however, if the scoring goes as planned, it should be pretty easy to see if you're in the lead and by how much. If your're way ahead, you might want to score for your opponent.
Also, I'm not sure planting yourself in front of a goal is the best way to defend, unless that's all the opponent can do. Strategy - it should be diverse this year.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 08-01-2006, 19:35
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Maybe no extra effort is really needed to consider you opponents score. One of my favorite components of this year's game is that balls scored by your opponents are given to your human players. So if you've got a shooting robot that just needs balls maybe letting them score some in the lower goals isn't so bad. Your three pts per ball sure beats the heck out of some one pointers.
Unread 08-01-2006, 19:47
OniKiller OniKiller is offline
FRC #1412
OniKiller is an unknown quantity at this point
a basket with a conveyor belt system would work...the balls would just keep rolling in.
"Changing the world one mistake at a time" --Team 142
Unread 08-01-2006, 19:55
FRC #1412
Unread 08-01-2006, 21:42
FRC #1412
Unread 08-01-2006, 22:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Possibly look at systems from '02 and '04. Teams like 1083, 330, and 33 all had systems that would intake and spit out balls really fast by reversing the intake motors. Systems like that could be very very valid again.
Statistical Analysis of Regional Competion Scores rourke Regional Competitions 9 08-04-2004 01:05
highest COMBINED score mentorn General Forum 15 28-03-2004 20:05
Will There Ever Be Negative Scores? Joe Matt General Forum 30 18-01-2003 17:15
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
visual aids for score keeping??? cam-man General Forum 3 24-03-2002 21:37
