Go to Post It is better to err on the side of caution than to put yourself in a position to have a referee or judge make a call against you. Build smart! - Sean Schuff [more]
Unread 08-01-2006, 16:05
Seekthematrix Seekthematrix is offline
FRC #1257
Seekthematrix can only hope to improve
Re: Best Way to Shoot the Balls??
well they give us those super cims(thats wat our team are calling them) anyone actually know the names of those motors. Those things could probley power a scooter. But a double belt system working on one of the motors or a one belt up inside a large barrel it would be fast accurate and easy to feed, with very little fear of jamming.
Unread 08-01-2006, 17:19
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
If you do a two-wheeled shooter (or two belt or whatnot), you could run the wheels at different speeds to put a backspin on the ball. Not all spin has to be like a spiraled football.
Making sure you get your wheels back up to speed before putting another ball it will be huge. High RPM and low torque wheels will slow down.
Who's taking a field trip to a batting cage?
Brian Graham
Unread 08-01-2006, 17:38
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
Originally Posted by ben281
I mean, you only have to get 1 out of 3 to make it worth your while, but it will prove to be very challenging, no doubt there. thanks for the input
Thats only assuming you can make one of three in the same amount of time it takes another robot to get three one point goals. Speed scoring and defense will be a factor as well as accuracy.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 08-01-2006, 17:54
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Lil' Lavery
Im trying to think of an effective way to rifle the ball in a mechanism similar to the softball laucher.
Simple: Use two wheels (not just one like the softball launcher), but put them at a slight angle to the direction of travel - for example, the top one is canted 15 degrees to the left (CCW) and the bottom one 15 to the right (also CCW). This is how football launchers work.
Originally Posted by iCurtis
With the spin the ball expeiriences being launched, and with the lightness of the ball, those balls will be going every which way immediately after they go through the launcher.
I disagree, and I see no need for a 'barrel'. In a protoype I built today (see photo), the balls went very very repeatably to the same spot. The biggest variable will be the supply voltage (= motor speed), but the astute student will figure out how to compensate for that ;-)
Originally Posted by I'mwithstupid^
I think that it would be easy to do a pneumatic system that would be fast.
Umm, using what energy source? A tennis ball launcher uses what is essentially a vacuum cleaner, blowing instead of pulling, and shoots the ball out of a 'barrel'. Longer barrels shoot further and flatter, and a screw-thingie on one side imparts spin. But, a 7 ball needs a LOT of air volume. Do the math with a 2' long barrel - what is the volume of the barrel in cubic feet, and how many cubic feet per minute at (60?) PSI can that KOP compressor supply? That gives you your best firing rate, BUT there is no place to store that volume of air at 60 PSI on a legal robot.
The way I see it, the only viable options are wheel-based and spring-based launchers. (A trebuchet is spring-based [EDIT: No, it is powered by a falling mass[/EDIT], and I agree, it would be soooo cool).
In the photo, that is an 8" wheel. At about 1300 RPM it launches a 7" soccer ball about 10 feet (from a table 40" from the floor), and in ten tries they all landed within an inch of each other.
The biggest issues are balance of the wheel - it wobbles a lot at 1300 RPM, it's not made for that - and the huge black marks the rubber leaves on the ball.
Don
Last edited by DonRotolo : 08-01-2006 at 21:21. Reason: A trebuchet is NOT spring-powered!
Unread 08-01-2006, 18:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Am I the only person thinking about ball availability? If you're on offense, and the opposing team is on defense, they have no reason to put balls in play where you can get them after you score them. So if you have 40 balls and score them all as one pointers, you get 40 points and have to wait until they give you your balls back. If you make 3's, you get 3 points. the ones you miss are still available to you if you have a ball scoop, so if you start with 40 balls you could get a max of 120 points before you've run out of balls.
Unread 08-01-2006, 18:43
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
Originally Posted by Don Rotolo
The way I see it, the only viable options are wheel-based and spring-based launchers. (A trebuchet is spring-based, and I agree, it would be soooo cool).
I hate to call you on a technicality, but this is a bet of a pet peeve. So, for the enlightenment of all,
A trebuchet is *not* spring powered. A trebuchet derives it's energy from a falling mass. Remember the really cool looking things that threw the giant rocks from Minas Tirith in the Return of the King? Those were Trebuchets.
If it uses elastically derived energy it is another kind of catapult. So, if you use a rubber band, spring, or the bowing of wood (or something else) to throw the object it's a catapult.
To clarify, a trebuchet is a *kind* of catapult. One that uses a falling mass.
More info here (Trebuchets) and here Catapults
- Toby
Unread 08-01-2006, 21:08
ben281's Avatar
ben281 ben281 is offline
Ben 281
AKA: Ben Grier
#0281 (EnTech)
Team Role: Student
ben281 will become famous soon enough
Send a message via AIM to ben281
haha, i was going to also mention this toby, but you got there first. but yes, a REAL trebuche would be totally awesome!
Unread 08-01-2006, 21:19
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, you're absolutely right and I stand corrected.
Don
Unread 08-01-2006, 22:59
occra 23.
AKA: ryo
None #1481
to the guy saying a simple cylinder pushing a ball out... not even close to enough. i tried a 3/4in bore cylinder at 100psi pushing a tennis ball. didnt get far at all. AT ALL.
so. to increase speed use simple machines. pulleys. lever arms... i htink thats the best bet... wondering about 60psi tho.... wish they let us use higher pressure ones.and 2 tanks... not enough for multiple fires.
im gonna think about motors..
Unread 09-01-2006, 00:05
Umm Errr...
We did some experimenting yesterday and built a number or prototypes. One of which was a pneumatic direct acting system that acheived a ball velocity of 8 m/s @60 psi. Its possible, but we have some tricks up our sleeves. We have a much more powerful version planned for monday or tuesday once some parts arrive.
1139 Alumni
Unread 09-01-2006, 00:23
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Are we allowed to create a chamber where the air compresses safely and the chamber is a cone with the ball that rolls back into it?
~~~~~O ~~~~~~ <-- Air in
----- Ball ---Chamber
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 09-01-2006, 00:51
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
I like the idea with two spinning wheels, like a hot wheels launcher. The important thing is that if the wheels aren't spinning at the same speed, the balls will fly off course.
Just food for thought.
Unread 09-01-2006, 01:16
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
I see no reason why you would need to shoot quickly if you have an accurate launching system. A barrel is probably necessary though. In my opinion, a pneumatic system would work best. There's less chance of unpredictable velocity... maybe. I donno though. I'm not the mechanical type. I just throw out ideas.
Unread 09-01-2006, 02:25
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Not necessarily. If you spin both wheels at the same speed, you end up with a ball without spin coming out of the shooter. And just like a knuckleball in baseball, the ball will zig zag in any and every direction. One of the solutions we came up with is to have the two wheel mounted one on top and one on bottom. You purposly gear down the top wheel a little more than the bottom one, which results in a slight backspin. This produces a shot that is very straight, with little to no sideways curve. If you go with one wheel instead of two, i would recommend mounting the wheel on the bottom, with a solid surface above it for the ball to pass through.
Both of these ideas are direct knock-offs of baseball and softball pitching machines, so google up some images if you need a visual reference
I personally would recommend going with the two wheels, just so that you can minimize spin. With a one wheel system, whatever spin you have, be it topspin or backspin, will always be directly related to the tangencial speed of the wheel. A two wheel system has the ability to greatly reduce this relation between spin and speed.
Michael C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 09-01-2006, 02:49
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
There are many more ways of quickly launching balls than it first appears. There are also a lot of "side effects" that people may experience from a particular idea. Some ideas will prove better than others, depending on the hardware and software behind them and how a particular team implements them. What works for one team might not work for another.
Earliar today, I had an ingenous idea on how to shoot balls accurately and quickly into the center goal. I already have it prototyped in Vex parts, and it launches the one raquetball every second about halfway across the room by [bleep] [bleep] [bleeeeeeeep] [bleepity] [bleep] and [bleeeeping] [bleepity] [bleep] [bleepment]. It's truly amazing.
Art Dutra IV
世上无难事,只怕有心人.
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
