Go to Post Are you prepared to be a team member? - JaneYoung [more]
Unread 08-01-2006, 22:13
psycho7 psycho7 is offline
pyscho
AKA: (ex-freshman)
FRC #1831 (Screaming Eagles)
Team Role: Scout
psycho7 is on a distinguished road
Send a message via AIM to psycho7
Re: best way to score in the lower goals ??
note about the ramps: I was at the main kickoff location and I expieremented with the lower goals. if you give the ball a gently push it will go into the goal. If you put any kind of real force behind the ball it will most likely not go in. Shooting or throwing the ball won't work either because of the height of the lower goal opening (something like 10 inches high or something).
Unread 11-01-2006, 01:06
insub2 insub2 is offline
None #1227
insub2 is an unknown quantity at this point
Re: Okay i've got a problem with the lower goals
Originally Posted by Davie Byrne
I can't seem to figure out how to get around this. If a robot just sits infront of a corner goal (Which it easily can), and anothr robot can't move it without latching on how is anybody going to score in the corner goals. Are there any loopholes to get around this?
the corner goals are 48" long by 10" high. the starting size for a robot is 38"x28". assuming the bot sitting didn't expand after start, that is a 10"x10" opening. it isn't much but it's something. ALSO, there is another corner goal and only one more defending bot. so that is 3 offense bots on 1 defense. so as long as one of the offensive allinace robots can shoot into the center goal, sitting in front of a corner goal is an ineffective stratagy.
further more, proventing the opposing team from scoring is cutting off balls to your human player.
i know all this has been said before. and once the rules are thought about, it all becomes farely evident.
in regards to this:
Originally Posted by Dakota Snow
I have been trying to figure out the best way to score in the lower goals. There is a ramp there in front of the goal So roling wound be trickly. Any one got some suggestions?
you could have a bot that picks up balls from the field or an open-top-hopper that your human player throws balls into. then you could have a "draw bridge" that lowers to about ...say.... 5" about above ground level and have a hopper with a slanted bottom. the balls in the hopper would roll right in after clearing a 1" high incline. ...or something like that...
hope that helps a little. i'm looking forward to seeing all the bots this year. oooo so excited.
Unread 11-01-2006, 18:12
Originally Posted by Lil' Lavery
Possibly look at systems from '02 and '04. Teams like 1083, 330, and 33 all had systems that would intake and spit out balls really fast by reversing the intake motors. Systems like that could be very very valid again.
330 has not done a small ball robot since 2000. 45 (2004) would be a better example here.
Statistical Analysis of Regional Competion Scores rourke Regional Competitions 9 08-04-2004 01:05
highest COMBINED score mentorn General Forum 15 28-03-2004 20:05
Will There Ever Be Negative Scores? Joe Matt General Forum 30 18-01-2003 17:15
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
visual aids for score keeping??? cam-man General Forum 3 24-03-2002 21:37
