Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 08-01-2006, 02:37
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Exclamation Inventor Help
I have Inventor 8. So i go to the Autodesk Streamline 6, log in etc. i download the Virtual Kit of Parts 2006.zip. I unzip it then try to open any particular file with Inventor.
then i get this error:
"! Database schema is newer than this version of the software"
that happens with any file from the Virtual KOP. the inventor parts from IFI open up fine, with no problems.
is there somewhere i can get a patch or fix for it? also the soft is updated according to the "Communication Center"
does this mean that the ONLY way i can use the Virtual KOP is to use the new inventor 10? i rather not do this.
BTW: i haven't had any problems with inventor 8.
thanks guys
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 08-01-2006, 02:50
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: Inventor Help
As far as i know you can't. Basically all it says is you need a new version of Inventor. I ran into this problem at my old high school because i would do drawings in invent 8 and the school only had inventor 5, so i could never work on stuff i had started at home in school. But sry I'm pretty sure you can't change it.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 08-01-2006, 03:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Inventor Help
You are correct. The only way you can view the VKOP is with Inventor 10.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2006, 08:39
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Inventor Help
That is like it was last year, you have to use the new version of Inventor to use the VKoP. You might be able to have someone with Inventor 10 save them as STEP files that you could open, then resave as Inventor files. But this does loose some things like constraints, and I think material properties. But if you can't use version 10, then redoing some parts of a file is better than doing them from scratch.
There are also a lot of parts that might help you in the FIRST CAD Library.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 08-01-2006, 14:25
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: Inventor Help
The parts posted in the FirstCadLibrary were created with Inventor 5 & 6. You should be able to open these just fine. I'm working on adding many of the new parts (as fast as I can).
Ed Sparks
MECH TECH FRC-3959
Unread 08-01-2006, 18:11
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Inventor Help
Thanks to the First CAD Library It's unfotunate that those of with older versions on Inventor (7 for me) can't use the FIRST VKoP.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 08-01-2006, 18:51
Happy Birthday! Goaliexam Goaliexam is offline
AKA: Max
FRC #1656 (Haverford Robotics)
Goaliexam is a jewel in the roughGoaliexam is a jewel in the roughGoaliexam is a jewel in the rough
Send a message via AIM to Goaliexam Send a message via MSN to Goaliexam
Re: Inventor Help
The FIRST Cad Library has almost all the models that the VKOP includes, and usually more detailed versions. You really aren't missing much.
Did you try using the 2005 VKOP? This year's is pretty similar to last year's, so if the 2005 version works for you then you should be pretty well off.
Unread 08-01-2006, 22:40
Gary Vrsek Gary Vrsek is offline
#1250 (Navigators)
Gary Vrsek is an unknown quantity at this point
Re: Inventor Help
I just opened up the virtual KOP and did not see the new CIM motor. I'm not that experienced with Inventor yet - is it in there with the visibility turned off??
gary
Unread 08-01-2006, 22:46
Re: Inventor Help
It's not in the 2006 VKOP.
Ed Sparks
MECH TECH FRC-3959
Unread 14-01-2006, 17:01
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
Re: Inventor Help
actually i am having this same problem. i have inventor 5 and 5.3 at home, inventor 8 parts, and inventor 10 on a tiny laptop that doesn't even meet minimum system requirements. unfortunately all of the official parts are in inventor 10 so i can only use the parts on the laptop
i have been trying to rebuild the parts in inventor 5 and solid works but the parts on the innovation site does not have dimensions. apparently they imported or something because it is only a base in inventor 10.
does anyone know where i can get parts that are editable so that i can change them to the older versions? i would appreciate it if anyone could give some info.
