Go to Post Have you hugged a Martian today? (Dave, don't answer that.) - Billfred [more]
Unread 08-01-2006, 23:58
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Zoom Question in Max
I mostly like working with a single large viewport, using the shortcut keys (L, T, F or U) to switch to the left, top, front or user views.
Sometimes when I switch views the mesh appears close up (a good thing). Other times it is far away and I have to zoom extents to get it close enough to work on it.
What determines the zoom level when you switch views?
Unread 09-01-2006, 02:02
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Re: Zoom Question in Max
Just a guess but porbably what you left it at last time. If you use the zoom extent, not zoom extend all, change the box from grey to white and i think if you select something in the animation it will zoom on it.
Unread 10-01-2006, 10:18
AKA: Kevin Thorp
It's not zooming to the last point I left a view. It zooms way out.
I have been clicking the Zoom Extents icon to get back to where I was, but it gets a little tedious having to do that every time I change the view.
Unread 10-01-2006, 22:01
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
When you are working with a model in different views, I would suggest to have the model selected, or have a vertex, polygon, edge, etc.. selected when switching views. If it seems far and you still have the object selected, press 'Z' to zoom in. When you said you had to use Zoom Extends All, I assume you are using the mouse to zoom in. Z is a shortcut It also helps to work with a three button mouse, the middle being the scroll button. I don't think there's a setting that you can change to adjust the zoom level.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
Quick 3ds max problm and question Jeremiah Johnson 3D Animation and Competition 5 31-01-2005 21:50
**FIRST EMAIL**/Gear Up with Live Inventor and 3ds max Trainings! Billfred FIRST E-Mail Blast Archive 0 22-12-2004 16:30
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
