Green Light Power Source
We went to build our green light that goes above center goal. We could not figure out how to power it. Does anyone know how it is to be powered? I know this should go on First site, but no one knows where the password for their site is. I was hoping to get a faster answer here.
Thanx |
Re: Green Light
As I recall their are green cold cathode tubes in the KOP, or are you asking how to power those? Their is also a included inverter, make sure you use it and don't try powering the tubes directly.
Re: Green Light
Connect it to a 12V power source. If you can find one anywhere, you might try to look for a 12V battery - that would probably work (hint, hint
Re: Green Light
Re: Green Light
Worth noting: The 8 cathodes and a small fan will require more than 1 amp to power. Our team has a 1 amp power supply that we hooked up to it, but it was only able to power the system at 8 volts.
I need to find where we put our spare Anderson hookup... |
Re: Green Light
Re: Green Light
An old computer supply makes a nice and cheap 12v power supply.
#8
Re: Green Light
Careful though you can make lots of magic smoke doing this wrong. You essentially short a specific wire, and shorting the wrong wire can be very bad. |
#9
Re: Green Light
I like this idea of a green LIGHT, it's a nice idea. |
#10
Re: Green Light
The last few years, we have had CCFL's very similar to the ones used for the vision target on our robot. The brightness is effected slightly by input voltage, but not too much until the battery gets really low.
#11
Re: Green Light Power Source
I'm assuming they included all the parts that normally come with a cold cathode tube kit, in which you could just hook it up to any computer with extra power connectors, or even just plug it into a power supply.
#12
Did you finally get it going? By now you may have put two and two together and found the power suppplies for the lamps. I think that was what you were asking. If you still have a problem, let me know. |
#13
Bob |
#14
Re: Green Light
Dave posted a hint here yesterday. but no one has tried to analyze it word by word. has something changed since the kickoff??? jerry w |
#15
yea i think if you use an old PS from a computer it would work. but i think u have to get a paperclip and stick the end in to 2 sprocket on the main feed from the power supply .. you have to do this because then the power supply is "fooled" by saying that there is a motherboard in place but really there isnt.. just google search it.. you will find it.
![]() Last edited by pheNIX637 : 11-01-2006 at 09:22. |
| TTL port to a serial port on a demo board | ImmortalAres | Programming | 16 | 09-07-2005 23:44 |
| How many users does it take to change a Light Bulb? | Matt Attallah | Chit-Chat | 4 | 04-09-2004 20:59 |
| program light blinks red and green | JBabbie | Programming | 3 | 02-03-2004 09:19 |
| Please...no more steenkin' light! | Andrew | General Forum | 37 | 17-04-2003 23:06 |
| Important info about light | Jay Lundy | Technical Discussion | 10 | 12-04-2002 11:37 |
