Go to Post I have never before seen the words "smaller" and "Saturn V" used in the same sentence. Wow. :yikes: - DonRotolo [more]
Unread 08-01-2006, 23:03
DonRotolo's Avatar
Back to humble
FRC #0832
Best way to collect balls off the field?
This thread is started to discuss ideas for getting balls off the floor and into the robot.
Last year at Nationals, the Vex folks had these cool rubber flappy wheels, and they would just pull those small balls right up into the robot. Anyone working on a larger version of that? Maybe brushes like a street sweeper, or arms that come out and sweep side to side (kinda like those nasty gathering 'bots that picked up older robots for the scrap heap, in the animated movie Robots)? After all, we have 60 x 60 to play with once the game's on...
Don
Unread 08-01-2006, 23:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Best way to collect balls off the field?
if possible, find some pictures from 2002 and 2004 games, tons of ideas there
Unread 09-01-2006, 11:23
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
possibly two cylinders with counter wound surgical tubing. they would spin inward
Unread 09-01-2006, 11:29
SURVIVORfan44's Avatar
SURVIVORfan44 SURVIVORfan44 is offline
SURVIVORfan44 is on a distinguished road
Send a message via AIM to SURVIVORfan44
I know I can think of one team that was VERY successful in 2004 with their robot that was basically a vacuum that took up all the balls on the field. I don't want to give it away because I don't want to ruin anyone's ideas.
Unread 09-01-2006, 11:38
SkiRacer SkiRacer is offline
Measure once, cut twice
AKA: Andrew
FRC #1676 (Pi-Oneers)
SkiRacer is an unknown quantity at this point
Send a message via AIM to SkiRacer
[quote=SURVIVORfan44]I know I can think of one team that was VERY successful in 2004 with their robot that was basically a vacuum that took up all the balls on the field.
That's a very good idea, but is it possible to create a strong enough vacuum with the given compressor
Unread 09-01-2006, 11:40
ewankoff's Avatar
AKA: -=The WANK=-
yeah but isnt there a rule about only 60 psi?
Unread 09-01-2006, 11:56
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
There are many different ways to accomplish this task. I wouldn't saythat there is one better way than another - we have done it different ways over the years, the main difference this year is the ball itself. In the past the balls were either inflated rubber or soccer type. We haven't had to collect squishy (is that is a word) type balls.
It can be done mind you, but the dynamics is different from past years.
One good thing is that you probably won't tip yourself over, getting them into the machine.
Unread 09-01-2006, 12:05
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Ah, I so wish i was on a team again this year...I have so many good ideas
But my idea would be an opening like a woodchipper, with a fabric type roller (similar to 121 from 02) that brings the balls into the center of the bot where they are stored for expulsion!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 09-01-2006, 12:09
FIRSTgurl93 FIRSTgurl93 is offline
AKA: Stephanie Bekkers
FRC #0857 (Superior Roboworks)
FIRSTgurl93 is an unknown quantity at this point
Send a message via AIM to FIRSTgurl93
Don
Two years ago when we had to collect and score those kickballs?...well our team made a roller system to feed the balls into a hopper that was lined with mesh material as to let it expand as it filled up. We ended up doing very well and it was very efficient because we could suck up anything in our path and it rarely ever got jammed. They called us the "Laundry basket" robot, but our rollers were covered with a rubber material to grip the balls and the rollers went in a curved path to lead the balls into the hopper and the rollers also spun the other direction as to let the balls go back out the same way to score in the side goals.
Stephanie
Unread 09-01-2006, 12:26
hpman247 hpman247 is offline
FRC #0977
hpman247 is an unknown quantity at this point
Is this what you are referring to? .If so how did that work. I never saw it.
Unread 09-01-2006, 12:59
AKA: Mongo
Yes, exactly...
It was basically just that "no-stick" fabric that you use in your cupboards, they sewed it together into two big loops, and ran the system via a FP motor at a fairly good clip that fed into their collector, it was fantastic
Unread 09-01-2006, 13:23
...that "no-stick" fabric that you use in your cupboards,...
I hope you meant "no-slip".
Unread 09-01-2006, 13:47
AKA: Mongo
haha, yes...yes non-slip fabric
Unread 09-01-2006, 15:33
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
That was my idea exactly. Even down to the non slip cupboard fabric. I guess I'm not very innovative =). Too bad those skirts won't let you climb up the platform this year. Im sure you need wheels at the corners or slants on the front and back in order to score those 10 or 15 points for your alliance.
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
Unread 10-01-2006, 20:46
DonRotolo's Avatar
Back to humble
FRC #0832
How about a belt along the bottom of the robot, as the center of the robot gets 'stuck' on the top edge of the ramp, just power up the belt and !zoom!.
Stephanie
Thanks for the details - we were a rookie team last year, and so never got to see any of the ball pickerupper mechanisms developed.
The big blue belt at the leading edge of the robot is obviously intended to move balls upward - does the 'belt' closest to the center of the robot move too, or is it stationary. (It doesn't look like a loop). Also, what's the purpose of that white roller-like thingie at the middle of the belt - tension? or something else, too? And, just for clarity, where the belt hits the white roller, the belt is moving upward, right?
Thanks,
Don
We can extend beyond the playing field with our ball-knocker-offer??? Natchez Rules/Strategy 35 19-03-2004 09:35
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Numbers for thought: Are 10 black balls worth 30 seconds? archiver 2001 6 23-06-2002 22:42
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
