4.3.4.1 - onboard laser?
So, my question pertains to 4.3.4.1.
If I just tape a laser pointer to my bot that only turns on when I press the button on it is that legal? Thanks, - Erik |
Re: 4.3.4.1 - onboard laser?
P.S. If it's not against the rules it should be... |
I would say no, citing the first question the flowchart asks: "Is the part a safety hazard or likely to damage robots, the field, or interfere with the humans or the controls?" --> YES --> No!! It may not be used. |
The section that you are pointing to has nothing to do with laser pointers. In the past, laser pointer were deemed harmful additions, in that you cannot control where the beam is being directed and might cause vision loss in a competitor or observer. If you follow the flow chart in section 5, Robot Rules, "Is the part a safety hazard or likely to damage robots, the field, or interfere with the humans or the controls?", answer yes and the part may not be used.
Essentially this comes from the following in section 5, <R31> No devices or decorations are permitted on the robot that are intended to jam or interfere with the operation of the vision system (i.e. changing robot color to confuse opponent’s vision system). Sorry |
if you are in fact using it to aim, one could plausibly have the robot do some math for you using the angle that the CMU cam is at (my team programmer says that it does that this year) and do some trig using the height of the target the CMUcam follows and how far your robot shoots to have the robot light up a fire at will light on your control area. Or, even better, you could have a robot that fires at will when a shitch is flipped once it checks that it is within the correct angle ranges for the ball to go in. (again, the angles (verticle and horizontal) are returned to you by the CMUcam)
#8
So I pose it again, anything illegal? |
#10
Actually, the laser qualifies as a MECHANISM. One of the PARTs in that mechanism is the laser battery. This battery is not allowed, because it is an energy source.
It's all in the manual, pretty clearly. |
#12
Not to mention the fact you can't "tape it to the robot" like you say, without violating <R33>.
#13
If you were to power this mechanism through the robot battery, then what? Matt |
#14
One should note that there is such thing as an "eye safe" laser, which transmits at a frequency that doesn't harm the eyes because it is absorbed by the cornea rather than being focused on the retina. As long as such a device is used in good faith (you know, as in it isn't green and it isn't shone on the other drivers), none of Mike's above cited rules appear to be violated.
| laser pointer | 1574aviad | Technical Discussion | 9 | 20-02-2005 20:25 |
| Second Annual Laser Quest Lock-in! | Gui Cavalcanti | Off-Season Events | 3 | 29-04-2004 23:33 |
| laser radar with BS2p using RS232 problems... | chei_UCF19 | Programming | 6 | 26-02-2004 15:21 |
| Onboard Camera? | XRaVeNX | General Forum | 18 | 03-02-2003 20:28 |
| laser guidence for a basic stamp brained valve cover racer | Andrew Wyatt | Technical Discussion | 1 | 05-06-2002 00:14 |
