Go to Post To go a step further, to be "steam punk", electrics would need to be powered from a steam turbine operated dynamo but electric wiring would still be required to follow all rules as they would apply. - Al Skierkiewicz [more]
Unread 09-01-2006, 13:37
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
4.3.4.1 - onboard laser?
So, my question pertains to 4.3.4.1.
If I just tape a laser pointer to my bot that only turns on when I press the button on it is that legal?
Thanks,
- Erik
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 09-01-2006, 13:58
Re: 4.3.4.1 - onboard laser?
Just don't use it at Portland when I'm sitting in the stands, OK?
P.S. If it's not against the rules it should be...
Unread 09-01-2006, 14:03
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Refer to the Parts Use Flowchart on page 14 of section 5 to determine if it is legal.
I would say no, citing the first question the flowchart asks:
"Is the part a safety hazard or likely to damage robots, the field, or interfere with the humans or the controls?" --> YES --> No!! It may not be used.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 09-01-2006, 14:09
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
If I understand its purpose correctly: to determine where your cannon is aimed. I don't understand why you don't tape it on and remove it when it is needed. Regardless of whether or not a robot accidentally turns it on, you might break it.
Unread 09-01-2006, 14:10
The section that you are pointing to has nothing to do with laser pointers. In the past, laser pointer were deemed harmful additions, in that you cannot control where the beam is being directed and might cause vision loss in a competitor or observer. If you follow the flow chart in section 5, Robot Rules, "Is the part a safety hazard or likely to damage robots, the field, or interfere with the humans or the controls?", answer yes and the part may not be used.
Essentially this comes from the following in section 5,
<R31> No devices or decorations are permitted on the robot that are intended to jam or interfere with the
operation of the vision system (i.e. changing robot color to confuse opponent’s vision system).
Sorry
Unread 09-01-2006, 14:44
satyagrah4 satyagrah4 is offline
Student Ambassador Coordinator
AKA: Matthew Vaerewyck
no team (FIRST)
satyagrah4 is an unknown quantity at this point
Send a message via AIM to satyagrah4
Why not just fit a flashlight to an end of a pvc tube? If you have a bright enough light/ make it like orange or something it is normal non-interfering visible light...
Unread 09-01-2006, 14:49
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
if you are in fact using it to aim, one could plausibly have the robot do some math for you using the angle that the CMU cam is at (my team programmer says that it does that this year) and do some trig using the height of the target the CMUcam follows and how far your robot shoots to have the robot light up a fire at will light on your control area. Or, even better, you could have a robot that fires at will when a shitch is flipped once it checks that it is within the correct angle ranges for the ball to go in. (again, the angles (verticle and horizontal) are returned to you by the CMUcam)
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 09-01-2006, 15:04
Best Available Data
FRC #1778 (Chill Out!)
I don't know about you, but if someone's flashing a flashlight in my eyes, I'd get kind of distracted.
Unread 09-01-2006, 15:17
AKA: Erik Thulin
I should have been clearer for the purpose. First of all it would be mounted about 2in above the ground. It would never be on during the operation of the robot. The point of it is to aim the robot PRIOR to atonomous. Their is no safety hazard as it is pointed so low, just on the field to align the bot prior to driving.
So I pose it again, anything illegal?
Unread 09-01-2006, 15:30
Carpe diem
Originally Posted by G11
Alignment Devices - Alignment devices (templates, tape measures, lasers, etc.) that are not part of the ROBOT may not be used to assist with positioning the ROBOT. Teams that use external alignment devices to position their ROBOT will have their ROBOT arbitrarily repositioned by the head referee.
If you consider the laser part of the robot it would not pass the acceptable parts flow chart because it is a safety concern. If you say it's not part of the robot than it would violate G11: it would be an alignment device. Therefore, although the laser is not explicitly banned, your robot might be arbitrarily moved by the head referee. Doing something that violates a rule with the hope that you won't get caught violates gracious professionalism.
Unread 09-01-2006, 15:42
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Actually, the laser qualifies as a MECHANISM. One of the PARTs in that mechanism is the laser battery. This battery is not allowed, because it is an energy source.
It's all in the manual, pretty clearly.
Unread 09-01-2006, 15:43
JVN JVN is offline
@JohnVNeun
Not to mention the fact you can't "tape it to the robot" like you say, without violating <R33>.
Unread 09-01-2006, 15:45
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Question Re: 4.3.4.1 - onboard laser?
Agreed.
If you were to power this mechanism through the robot battery, then what?
Matt
Unread 09-01-2006, 16:24
Carpe diem
Originally Posted by <R02>
Energy used by FIRST Robotics Competition robots, (i.e., stored at the start of a match), may only come
from the following sources:
• Electrical energy derived from the onboard 12V and 7.2V batteries
Originally Posted by <R51>
The only legal main source of electrical energy on the robot is one of the two 12v DC non-spillable lead
acid batteries provided in the Kit of Parts, or a spare of the same part number.
If you were to include the laser pointer as a part of the robot with its internal battery it would violate <R02> and <R51>.
I don't think you can answer Yes to this question.
Originally Posted by <R40>
Additional Parts shall not be made from hazardous materials or be unsafe.
I would say mounting a laser pointing away from your robot would be considered unsafe.
Originally Posted by <R58>
Inputs to custom circuits may be connected to the following sources:
• Branch Circuit breaker outputs
• Speed Controller or Relay module outputs
• PWM, Relay or Digital Outputs on Robot Controller
• Switches, Potentiometers, Accelerometers, Sensors, and other additional permitted electronics.
I would say that if the light source was safe, and didn't effect the vision targeting system than it would be considered a custom circuit and could be connected with respect to <R58>.
Unread 09-01-2006, 16:51
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
One should note that there is such thing as an "eye safe" laser, which transmits at a frequency that doesn't harm the eyes because it is absorbed by the cornea rather than being focused on the retina. As long as such a device is used in good faith (you know, as in it isn't green and it isn't shone on the other drivers), none of Mike's above cited rules appear to be violated.
laser pointer 1574aviad Technical Discussion 9 20-02-2005 20:25
Second Annual Laser Quest Lock-in! Gui Cavalcanti Off-Season Events 3 29-04-2004 23:33
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 26-02-2004 15:21
Onboard Camera? XRaVeNX General Forum 18 03-02-2003 20:28
laser guidence for a basic stamp brained valve cover racer Andrew Wyatt Technical Discussion 1 05-06-2002 00:14
