Go to Post Our robot weighed 168lbs..... bring it on Trimspa!!! - slickguy2007 [more]
Unread 09-01-2006, 17:17
Ryo_Himura's Avatar
Ryo_Himura Ryo_Himura is offline
Wazzup Homie
AKA: Ryo
FRC #1446 (Robo Knights)
Team Role: Animator
Ryo_Himura is an unknown quantity at this point
Send a message via AIM to Ryo_Himura
Uses for FP Motors?
Teams in DC are wondering what the Fisher Price motors are for.
Life is good get your own!!!
Unread 09-01-2006, 17:27
Re: Uses for FP Motors?
Whatever you decide to use them for, as long as you keep it legal. (The same is true for any motor in the kit. Just make sure you do the math to get the right one.)
Unread 09-01-2006, 17:40
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
I'd use them for anything but drivetrain
Unread 09-01-2006, 17:50
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
I second that one. We have used them for the drive train before but you have to watch their temperature it is very easy to over heat them and have them motors melt down. These motors have about half the torque that the little CIM has but they are still very powerful for their size.
Unread 09-01-2006, 17:57
Electrical Engineer
Rookie Year: 1995
The original use of the FP motors are for a child's motorized toy. What you will use it for is up to you.
As noted above, these are fan cooled motors and will rapidly (2 or 3 seconds) overheat and burn if stalled. This is because the fan is stopped and the internal losses are large in a stall condition...
Best of luck...
Mike
Mike Betts
As easy as 355/113...
Unread 09-01-2006, 18:32
Andrew Blair's Avatar
FRC #0306 (CRT)
Unless something has changed this year, (sorry, haven't checked the spec sheets) the power of the CIM and the FP are only separated by a few watts.
The biggest problem with FP's is that you can't really load them till they're close to stall, or they will smoke. You must design in a few hundred to thousand safety RPM to keep them cool.
-Sir Francis Bacon
-Albert Einstein
Unread 10-01-2006, 08:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Last year's FPs were 6V units running at 12V. So they were a heck of a lot more powerful. This year's FPs are true 12V units. Peak Power is about 170W. Pay no attention to the guidelines document, it's listing the power input at Peak Power. About half of which the motor is just turning into heat.
Unread 10-01-2006, 11:59
Does anyone have hard numbers on the new motors yet?
Unread 10-01-2006, 12:56
FRC #0254
All the motor specs are on FIRSTs website.
2006 FIRST Robotics Competition Kit of Parts Specification Sheets
Good Luck
~Kirk
Unread 10-01-2006, 13:07
Thanks, Kirk. I was looking for the tech information that they mentioned on the kick-off Webcast that was being worked out by 35 teams.
Unread 10-01-2006, 14:57
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Just a quick question are we allowed to use last years 6 volt fischer prices? I really loved their insane amount of power. Not that I think we need it per se this year, but a flywheeel hooked up to one could really... fly!
Team Website
Unread 10-01-2006, 15:11
Andy A. Andy A. is offline
Getting old
FRC #0095
The FP's thrive in conditions that require the high power in a small space and high RPM's.
They are good for things like running a ball roller system, where you need the high RPM and you can keep it running at that speed. It's also helpful that they have far and away the greatest power the weight/size ratio of any motor in the kit so packaging them is easier.
In fact, anytime you need to keep something spinning at a fairly consistent (high) speed is a possible FP use. It's not that a CIM motor can't do it, but they are probably better placed on a drive train or arm which will require more slow speed high torque operation.
-Andy A.
Unread 12-01-2006, 22:05
in between teams
AKA: Luke Van Oort
According to the rules the only FPs you can't use are '03 and '02. It doesn't say a thing about the '05 one.
Originally Posted by Section 5: The Robot
<R25>Motors, pumps, and, robot controllers from previous robots may not be used in addition to those provided
in the 2006 kit of parts. They may be used as direct one-to-one SPARE PARTS for those provided if the
provided part fails or is damaged. They may only be used if they are identical to the part being replaced (note
that 2002 and 2003 Fisher-Price motors are not the same as those in the 2006 kit, and, therefore, cannot be
used).
Team 1219: 2009 - Mentor
Unread 12-01-2006, 22:11
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Even with the andymark planetary transmissions? They gear them to be just lik a CIM so the only difference is s few watts right?
Unread 12-01-2006, 22:13
DonRotolo's Avatar
Back to humble
FRC #0832
sigh... We're working on it. It's been hard to shake loose the resources needed to build a dynamometer with the range to characterize all of the motors, but we're almost there. The design is not as trivial as it seems.
Take a look in the National Instruments and DAQ forums for the latest news.
Don
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
