Uses for FP Motors?
Teams in DC are wondering what the Fisher Price motors are for.
Re: Uses for FP Motors?
I'd use them for anything but drivetrain
As noted above, these are fan cooled motors and will rapidly (2 or 3 seconds) overheat and burn if stalled. This is because the fan is stopped and the internal losses are large in a stall condition... Best of luck... Mike |
Unless something has changed this year, (sorry, haven't checked the spec sheets) the power of the CIM and the FP are only separated by a few watts.
The biggest problem with FP's is that you can't really load them till they're close to stall, or they will smoke. You must design in a few hundred to thousand safety RPM to keep them cool. |
#7
Last year's FPs were 6V units running at 12V. So they were a heck of a lot more powerful. This year's FPs are true 12V units. Peak Power is about 170W. Pay no attention to the guidelines document, it's listing the power input at Peak Power. About half of which the motor is just turning into heat.
#8
2006 FIRST Robotics Competition Kit of Parts Specification Sheets Good Luck ~Kirk |
#10
Just a quick question are we allowed to use last years 6 volt fischer prices? I really loved their insane amount of power. Not that I think we need it per se this year, but a flywheeel hooked up to one could really... fly!
#12
The FP's thrive in conditions that require the high power in a small space and high RPM's.
They are good for things like running a ball roller system, where you need the high RPM and you can keep it running at that speed. It's also helpful that they have far and away the greatest power the weight/size ratio of any motor in the kit so packaging them is easier. In fact, anytime you need to keep something spinning at a fairly consistent (high) speed is a possible FP use. It's not that a CIM motor can't do it, but they are probably better placed on a drive train or arm which will require more slow speed high torque operation. -Andy A. |
#13
Take a look in the National Instruments and DAQ forums for the latest news. Don |
| Looking for practice motors & extra tape drive parts? | archiver | 2000 | 1 | 23-06-2002 22:54 |
| Suppose you want seat motors... | archiver | 2000 | 0 | 23-06-2002 22:50 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drill Motors | TF8 | Motors | 19 | 12-12-2001 13:13 |
