Go to Post FIRST is aimed at those girls on your team. They don't know anything about mechanics, or electricity, or programming, or machining. They have no interest in it, either. They're perfect candidates for FIRST. - Madison [more]
Unread 10-01-2006, 09:45
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: 4.3.4.1 - onboard laser?
Originally Posted by Ethulin
We have just decided to use a gun scope.
If I understand you correctly: you want to use a gun scope to align your robot once you place it on the field before a match; you can't! Rule <G11> explicitly forbids you from using ANY device for aligning your robot at the beginning of the match.
Unread 10-01-2006, 10:45
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
It says that alignment mechanisms that aren't part of the robot are illegal. If it is attached to the robot, then by rule G11 it would be legal.
Unread 10-01-2006, 11:40
Carpe diem
Yes, you are correct: a gun scope is allowed on a FIRST robot per the 2006 Parts Use Flow chart, if the cost of the scope is under $400 and the total cost of non-kit parts are under $3,500.
However, let's not "lawyer" rule <G11>. The intent of rule <G11> is for teams to quickly place their robots on the field without going through elaborate alignment methods. This means not using devices attached or unattached to the robot who's specific purpose is to align the robot. The kit of parts has been supplied with an abundant amount of sensors so that specific robot placement is unnecessary.
I'm not on the game committee, I'm not from FIRST. If you don't buy my answer you can ask FIRST for a clarification and more specifically the intent of rule <G11>.
Unread 10-01-2006, 13:37
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
Well our analysis of the rules came to the same conclusion as it WOULD be mounted on the bot. We will ask in ask FIRST thoughr
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
laser pointer 1574aviad Technical Discussion 9 20-02-2005 20:25
Second Annual Laser Quest Lock-in! Gui Cavalcanti Off-Season Events 3 29-04-2004 23:33
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 26-02-2004 15:21
Onboard Camera? XRaVeNX General Forum 18 03-02-2003 20:28
laser guidence for a basic stamp brained valve cover racer Andrew Wyatt Technical Discussion 1 05-06-2002 00:14
