Go to Post I'll admit that the events at Epcot were pretty nice, but they too had their problems. . . You were at the mercy of the weather, and Disney hasn't figured out how to control that yet. - Kevin Sevcik [more]
Unread 08-01-2006, 23:36
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Minimum Clearance?
So with the angle of the ramp, and assuming you have a bot that is the maximum dimensions (28 * 38), how much ground clearance do you have to have between the underside of the robot and the ground to clear the ramp without getting stuck? I know it's probably an easy math problem but I haven't figured it out and other teams would probably benefit from this answer being public.
So... anyone wanna take a crack at it?
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 08-01-2006, 23:39
uberrabbits uberrabbits is offline
FRC #0991
uberrabbits is an unknown quantity at this point
Re: Minimum Clearance?
okay. Whats the distance between the wheels? And do you want to know if it will get started up or when it hits the top? You might run into issues with a bumper...
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I take it you mean driving perpindicular to the wall.
(ie: Straight onto the ramp)
Interesting question.
I'll see what I can come up with in CAD, but to effectively do that you can use some algebra and angle it all out. Good Luck.
Unread 08-01-2006, 23:55
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
I attached an Excel sheet I created back in 2003 (along with a bunch of other such handy reference calculations) to figure these out. I never had time to document these and put in a white paper. I hope it is pretty self explanatory.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 09-01-2006, 00:00
BTW - keep in mind that the clearance could be greater while driving on the transition of the ramp parallel to it rather than perpendicular to it. For the example in the sheet I attached, where the robot front is 38 wide, would require greater clearance in the front clearance orientation than in the side orientation.
Unread 09-01-2006, 01:43
Eric Whitman Eric Whitman is offline
FRC #1257
Eric Whitman is on a distinguished road
Send a message via AIM to Eric Whitman
I believe the minimum clearance you need is:
0.134*(the distance between your wheels) = minimum clearance
I wouldn't rely on that math without checking it.
To explain how I got that:
0.134 = tan(15)/2
If the ramp is 30 degrees, the angle at the top is 150 degrees
When the corner is evenly between your wheels, the angle between the bottom of your robot and the ground is 15 degrees on either side of the corner: (15*2 + 150 = 180)
tan(15) = (clearance distance)/(1/2)*(distance between your wheels)
Solving for (clearance distance) yields the above equation
That look right?
Unread 09-01-2006, 01:45
kenz9000's Avatar
kenz9000 kenz9000 is offline
AKA: Mackenzie McNutt
FRC #0001 (Juggernauts)
Team Role: Electrical
kenz9000 is an unknown quantity at this point
Send a message via AIM to kenz9000
well the bumper cant be any lower than 2.5 inches, correct??
Mackenzie
2005
Team 1, Juggernaut Captain, Electrical Guy
First Seed at GLR
Semi Finalists w/ 1126 and 378 At Buckeye
Unread 09-01-2006, 07:07
If you (or your teammates) don't trust your math skills completely, you can use physical models. It doesn't take long to put a couple of wheels on the ends of a stick and play with them on a ramp. I was surprised to find how little clearance it takes for a six-wheel robot to make it over the top.
Unread 09-01-2006, 14:35
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
Thats one of the advantages of a six wheeled robot, given that the wheels are aligned with three on each side, for even if one pair loses traction, there are still two pairs in contact, and thus the robot will not end up getting hung up on the top of the ramp. On the bottom, it acts identical to a four wheeled robot.
Unread 10-01-2006, 11:13
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
0.134*(the distance between your wheels) = minimum clearance...
One issue that Eric and I didn't consider at first but is certainly important is that you need to look at the clearance between not just in the side view, but also in the front view of the robot. The clearance should be calculated for both the case when the robot is facing directly up the ramp, and when it is perpendicular to it as the relevant distance between the wheels changes between the cases.
Chances are your forward direction will have a shorter wheel base and require lower clearance than the sideways direction. This means that you may be able to safely drive up the ramp without bottoming out but then turn 90degrees while still half on the ramp and bottom out.
Team 1257
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
Victor Muffin Fans - Height Clearance? Mr. Lim Electrical 4 28-01-2005 15:32
Anyone going under the rail? archiver 2001 17 23-06-2002 22:41
