Go to Post In fact, one of our volunteers just found out about the entire FIRST program two weeks ago and had so much fun on Thursday that he came back on Friday to help us again! - KathieK [more]
Unread 10-01-2006, 11:12
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Code error on RC after downloading "bells and whistles" version of Kevins camera code
Hi all,
After making sure that the camera was connected properly (Pan and tilt pwms connected to pwms 01 and 02, TTL adapter connected properly, and cam's power connected to an unused pwm), I downloaded Kevin's "bells and whistles" camera code to the robot controller. After being downloaded with the correct version of IFI Loader, the IFI Terminal was blank and the RC was showing a code error.
Any ideas of what can be wrong?
Thanks,
Unread 10-01-2006, 11:57
Electrical Engineer
Rookie Year: 1995
Re: Code error on RC after downloading "bells and whistles" version of Kevins camera
Have you been successful in downloading anything at all to this controller? In other words, have you tried the 2006 default code from IFI?
Mike Betts
As easy as 355/113...
Unread 10-01-2006, 12:02
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Code error on RC after downloading "bells and whistles" version of Kevins camera code
Originally Posted by dhoizner
Hi all,
Thanks,
You're using a 2006 controller? Did it die immediately, with nothing on the terminal screen? Are you using a USB to RS232 converter?
-Kevin
Kevin Watson
http://kevin.org
Unread 10-01-2006, 15:19
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Sorry for making it not clear, but I'm using a 2005 controller that is functioning (when I download last years program onto it, it runs fine).
Any ideas?
Unread 10-01-2006, 15:27
Are you using the updated versions of MPLAB and CBOT Compiler? The new processor for 2006 requires a different compiler than past years.
Unread 10-01-2006, 16:43
FRC #2429
Any ideas?
The code is built for the 2006 controller, which has a different CPU in it. Get a copy of the 2005 default code and follow the instructions in the various readme files to get the code working on your controller.
-Kevin
Kevin Watson
http://kevin.org
Unread 10-01-2006, 18:07
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Hi Kevin, we tried the 2006 controller and it worked.
The reason I tried on last years controller was because in the readme files it said that the code was usable with both the new and old controllers. I guess I misunderstood and it was really the camera module in the code that was portable.
Sorry for the mixup,
