Go to Post Don't bring a distraction to the field. - Al Skierkiewicz [more]
Unread 10-01-2006, 14:05
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: Calculating Angle to fire at
Why so complicated? Build your shooter and iterate through the ranges, keeping track of the shooter launch angle and camera tilt servo position. Then all you have to do is look up the value for the shooter angle based on the camera tilt servo and forget about the range. You can use a joystick button to add a fixed offset to adjust in realtime if something changes on the field and it starts missing.
When I tested the camera code I could only get about 20' away before the trackable pixel area becomes too small. At 6" increments your lookup table is only 40 entries long.
Viewing Angle of Camera Joe Johnson Technical Discussion 10 14-01-2005 14:11
Calc. Triangle Angle or Side Based on Ellipses? indieFan Math and Science 1 07-06-2004 21:25
Serious VCU Fire Joe Matt Chit-Chat 3 26-03-2004 19:04
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
