Go to Post The Lord of the Bots.... - Bob Steele [more]
  #31   Spotlight this post!
Unread 10-01-2006, 14:05
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: Calculating Angle to fire at
Why so complicated? Build your shooter and iterate through the ranges, keeping track of the shooter launch angle and camera tilt servo position. Then all you have to do is look up the value for the shooter angle based on the camera tilt servo and forget about the range. You can use a joystick button to add a fixed offset to adjust in realtime if something changes on the field and it starts missing.
When I tested the camera code I could only get about 20' away before the trackable pixel area becomes too small. At 6" increments your lookup table is only 40 entries long.
  #32   Spotlight this post!
Unread 10-01-2006, 15:15
I agree with Sean. With so many variables in the system the only sane way to approach this is by testing your shooter, and averaging the results for each angle or distance or launch velocity, then using a look up table for each distance (or angle)
and if possible, only allow your launcher to vary one setting (angle or launch velocity).
Rick had a good point. In the real world military pilots let the computer do all their magic, they pull the trigger, then they use a joystick to walk the rounds into the target.
Even an A10 warthog with its computer controlled targeting system cannot hit a target 1 mile away with the first round (bullet).
  #33   Spotlight this post!
Unread 10-01-2006, 16:44
varcsscotty varcsscotty is offline
Programmer
FRC #1571 (Braughtswurst)
varcsscotty is an unknown quantity at this point
it's not the only way trust me....
"If you want the best, try the Wurst!"
  #34   Spotlight this post!
Unread 11-01-2006, 20:24
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
While I agree that a table lookup would be a lot easier, why not go all out this year, and use the CPU that was given to you, and calculate on the fly. I know that is what my team is doing. While a hash table would be fast, it would be less accurate, and we are personally looking for going for the perfect bullseye at least 60% of the time.
  #35   Spotlight this post!
Unread 11-01-2006, 20:35
the reason for using a lookup table is something they don't tell you in college. The real world in not linear. There IS no equation for the trajectory of a foam ball through the air for different angles, launch velocities or distances.
You can come up with equations that approximate what the foam ball will do when you launch it from your robot, or you can test fire the mechanism several times, record the results, and know exactly what it will do as each variable in your system is changed.
No matter what equation you use, your going to have to test fire your launcher to get its actual parameters, so you have to go through the same procedure anyway.
but once you test fire your launcher over its range of settings, and measure the results, you now HAVE the answers to the equations you need to write. At that point why calculate the answers each time you fire the launcher? you already measured the results during testing.
besides, a lookup table in SW takes 2 or 3 simple instructions to execute. You add a variable to the table start address, and read the answer from that memory location.
Trig functions on a microprocessor can take hundreds of instruction cycles to calculate.
"everything should be as simple as possible, but not simpler" -Einstein
  #36   Spotlight this post!
Unread 11-01-2006, 20:45
FRC #0701 (RoboVikes)
I think we may also end up using the same method... collecting real life data.
Calculating it is less accurate due all the real world factors that are out of control and too hard or random to factor in(friction, spin etc.)
Team 701
  #37   Spotlight this post!
Unread 11-01-2006, 21:06
AKA: Bert JW Regeer
Ah, I knew I was missing something. I see why a lookup table would make more sense.
My Blog!
  #38   Spotlight this post!
Unread 11-01-2006, 22:58
None #0116
Theres nothing wrong with that approach, but time is a finite resource and it is not the hardest problem here. It seems to me there are two very difficult problems involved:
1) Build a contraption that consistently shoots the balls at roughly the same speed (and hopefully direction!)
2) Build a gimbal mount that can be quickly and accurately positioned to control the launch angle for the gizmo in part 1.
I think part 2 will be the deal breaker for most teams. Moving an appendage is one thing, but this requires tight tolerances to make it work.
  #39   Spotlight this post!
Unread 11-01-2006, 23:57
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
The KISS rule probably applies here (as in most things in life).
You need to understand the relative complexity of items #1 (consistent speed) vs. #2 (agile and accurate gimbal mechanism) and factor in the relative importance of 1 vs. 2. It seems to me that unless you plan to alter the launch angle based on the launch velocity on the current shot, #2 is not very important. If you shoot the ball at fixed angle and consistent speed, you should be able to deliver the ball in the proper height over a rather large range from the goal. I think that's the key in this game.
Hint: play around with the Excel spreadsheet I posted earlier in this thread, now attached below with a minor correction. I now divide by 8 in the drag factor parameter instead of multiplying by 0.128 (obviously I meant to multiply 0.125 in the original version...2% error - my bad!)
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Last edited by David Brinza : 12-01-2006 at 00:13. Reason: Attached revised Excel spreadsheet
  #40   Spotlight this post!
Unread 12-01-2006, 13:49
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
if anyone uses mathematica, here's a notebook to generate ballistic lookup tables..
initial values are declared at the top, target height is deltah (3.5 ft or whatever) * ft-> meter conversion.
all values should be done in metric.. at the end, just display the contents (or export to CSV) and load em onto the bot.
I'm sure a few of you'll figgure out some more inventive uses..
<-- currently working on a 3-dimentional version.
No, I'm not a programmer.
  #41   Spotlight this post!
Unread 12-01-2006, 14:18
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Another variable to your equations might be the "plug" that these balls have on them. The plug must be a necessary part of the manufacturing process. It really makes them wobble if any spin is introduced.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
  #42   Spotlight this post!
Unread 12-01-2006, 19:20
BotLobsta BotLobsta is offline
FRC #1477
BotLobsta is an unknown quantity at this point
I added the equation that Matt came up with into my firing calculations to have a basic trajectory to test with, and I got the following error:
Error - section 'MATH_DATA' can not fit the section. Section 'MATH_DATA' length=0x00000014
I looked in the linker script and could not find that section, nor could I find mention of it anywhere else in any documentation. Any help?
  #43   Spotlight this post!
Unread 12-01-2006, 21:47
those of you intending to use lookup tables, here's a lookup table for you to play around with..
its around 108kb, but you can trim it by deleting the first portion (the ball wont even go in)
first column, theta
second column {distance-to-goal,total-distance-traveled-till-ground,risidual error}
risidual error shouldn't matter unless you're seriously nitpicky, it'll give you a relative idea of how much error there is for each theta..
  #44   Spotlight this post!
Unread 13-01-2006, 18:24
Korbin's Avatar
Korbin Korbin is offline
FRC #1011 (CRUSH)
Korbin is an unknown quantity at this point
Send a message via AIM to Korbin
was this tested using the four bulbs that came in the kit, or with all eight that will be used in competition?
  #45   Spotlight this post!
Unread 13-01-2006, 19:51
Andrew Blair's Avatar
FRC #0306 (CRT)
There are eight cathode included in the KOP. Two per box. But I also wonder if only four were used; we were considering it, though we used eight, and with eight, it is pretty bright. But we haven't tested yet.
-Sir Francis Bacon
-Albert Einstein
Viewing Angle of Camera Joe Johnson Technical Discussion 10 14-01-2005 14:11
Calc. Triangle Angle or Side Based on Ellipses? indieFan Math and Science 1 07-06-2004 21:25
Serious VCU Fire Joe Matt Chit-Chat 3 26-03-2004 19:04
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
