Re: CMU Cam prosseser running hot
I hate to ask the obvious but... are you using a PWM cable to provide power from an unused PWM output on the RC and do you have a 7.2 backup battery installed on the RC? If you are attempting to power the camera from 12 volts (main battery) or another power source, through some other cable or connection, the camera may be over voltage. Specs are 5.2 to 8.6 volts max on power input.
| cmu cam programming ideas | mwtidd | Programming | 1 | 09-01-2006 12:41 |
| Video of the (not so) humble beginnings of the CMU cam. | Elgin Clock | Programming | 0 | 29-03-2005 21:31 |
| CMU Cam GUI | Arc736UV | Programming | 2 | 15-03-2005 19:26 |
| CMU Cam servo jitter | adamdb | Programming | 3 | 01-02-2005 14:42 |
| CMU cam and Linux? | scitobor 617 | Programming | 2 | 30-01-2005 23:02 |
