Go to Post it should not matter the gender of a person but rather their ability. - vivek16 [more]
Unread 10-01-2006, 13:36
kjhobin kjhobin is offline
AKA: Keith Hobin
FRC #3314 (Mechanical Mustangs)
kjhobin is a jewel in the roughkjhobin is a jewel in the roughkjhobin is a jewel in the rough
Send a message via AIM to kjhobin
CMU Cam prosseser running hot
Has anyone noticed that the processor on the 2006 CMU cam in running hot, as in it might burn you if you leave your finger on it long enough. Is it just messed up or should our team return it?
Montclair Robotics FIRST Team 555 Alumni
FIRST Volenteer
Unread 10-01-2006, 14:18
Re: CMU Cam prosseser running hot
I hate to ask the obvious but... are you using a PWM cable to provide power from an unused PWM output on the RC and do you have a 7.2 backup battery installed on the RC? If you are attempting to power the camera from 12 volts (main battery) or another power source, through some other cable or connection, the camera may be over voltage. Specs are 5.2 to 8.6 volts max on power input.
Unread 10-01-2006, 15:05
flearocksmybass flearocksmybass is offline
AKA: Ben
FRC #0555
Team Role: Electrical
flearocksmybass is an unknown quantity at this point
Send a message via AIM to flearocksmybass
i am on team 555 who started this thread, and we are running the rc with just the backup battery and a pwm to the camera. and the processor on the board is hot enough to burn someones finger.
Unread 10-01-2006, 15:27
It sounds like the local regulator may be shorted. I would contact IFI for advice, return authorization , etc. The proc should not burn fingers.
Unread 10-01-2006, 21:57
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
The power regulator in the CMUCam is rated up to 15 volts, so I doubt 12 would make it hot.
Zan Hecht
cmu cam programming ideas mwtidd Programming 1 09-01-2006 12:41
Video of the (not so) humble beginnings of the CMU cam. Elgin Clock Programming 0 29-03-2005 21:31
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
CMU Cam servo jitter adamdb Programming 3 01-02-2005 14:42
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
