Go to Post To quote Harrison Ford: "Never tell me the odds". - [more]
Unread 10-01-2006, 16:28
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
question about the code
why track_green variable is only in yCrCb mode if i'm work in the RGB mode ?
and anthore question RGB means Red-Green-Blue where the yellow comes from?
Unread 10-01-2006, 16:42
Re: question about the code
I can't answer your main question, but the alternate color scheme to RGB for printing is CYM, or cyan, yellow, and magenta. You can Google on CYM or CYMK, or read about on Wikipedia.
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Need Advice On Code Out Of Box...New To This gemccnp Programming 4 30-01-2005 18:57
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
