Go to Post I think the best driver team of the post season would be Mike Wade and Pete Baltzell- because they have been driving that NASA field all over the Northeast so all of us can play.Thanks guys!! - Wayne C. [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2006, 18:38
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Anybody build the given 2006 Transmission
Here is the manual:
http://www.ifirobotics.com/docs/2006...nual-rev-d.pdf
This transmission is the same as the one that appeared in the 2005 kit, as part of the Kitbot robot. Many teams used it with great success. If you search these forums you can learn more about how it was used in 2005.
Unread 10-01-2006, 18:54
Andrew Blair's Avatar
FRC #0306 (CRT)
There have been a few modificataions though, right John? I mean specifically the rear face plate. It seems to be working better for us. It has more holes; what are the all for?
-Sir Francis Bacon
-Albert Einstein
Unread 10-01-2006, 19:29
JVN JVN is offline
@JohnVNeun
The new holes on the rear face plate are for mounting the Gear-Tooth Sensor included in the KOP. There were no other modifications besides this.
Glad to hear it's working better; though I can't guess why.
-JV
Unread 10-01-2006, 19:54
FRC #0306 (CRT)
Eh, don't know, but they run much smoother than last years. We built them and ran them in today, and they are performing much better. Maybe we screwed them down with more/less backlash? Either way, they sound much better.
-Sir Francis Bacon
-Albert Einstein
Unread 10-01-2006, 21:09
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Thats good to hear...our gearboxes made all sorts of cool grinding noises when we turned .
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 10-01-2006, 21:11
FRC #0306 (CRT)
Umm...Hmmm. Grinding is bad. If you can, lube them up real well and run them for like 20 minutes. All gearboxes need to wear in. But if it's a really, really bad grinding noise, somethings wrong. They are not silent by any means, but grinding shouldn't happen.
-Sir Francis Bacon
-Albert Einstein
Unread 10-01-2006, 22:55
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
just wondering if it would work. But if you take an old KOP tranny and seal it up with a gasget on front and seal all the bearings in it( flanged bearings on gasgets?) would it work fine to run it in transmission fluid or sorthing of the sort? like for an off-season project.
Unread 11-01-2006, 00:17
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
I see in the robot part of the manual that we can use up to four "small CIM motors. Does this mean we can use four transmssions too?
Unread 11-01-2006, 00:29
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
You can..but each gearbox w/o motor at 13.4 lbs, and 4 of them being 53.6 lbs, leaving 66.4 lbs for the chassis, electronics, and shooting mechanism, might not be the best idea in my opinion, but might be perfect for your design.
Unless you need a lot of extra weight, I think just having 2 transmissions should be fine for a tank drive robot, unless you're planning on having a holonomic with the 4 transmissions in the corners driving 4 omniwheels independently.
Unread 11-01-2006, 00:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If this is the case, another good solution is to use the Nothing But DeWalts whitepaper to convert four DeWalt transmissions for use with the CIM's, and mount them in the corners.
2001-2004: Team 100
2006-Present: Team 254
Where do you actually build your robot and who does the building??? Elgin Clock General Forum 47 14-11-2006 17:50
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
