Go to Post It is usually the simple things that get you. - Andy Brockway [more]
Unread 09-01-2006, 12:04
First FIRST ball launcher?
Prototype ball launching system. Delta bench sander, Porter Cable 361 belt sander, various scrap lumber, and some drywall screws -- VIOLA! Or voila. Something like that. Anyway, the project took two hours.
The belts run at about 4mps, and the ball goes a maximum of about 4 meters. You're going to want to go for the full 12mps max velocity.
Name:	1294 Prototype Launcher.jpg
Unread 09-01-2006, 12:49
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Re: First FIRST ball launcher?
Congrats for being the "first" FIRST ball launcher.
This technology brings up an interesting question;
What if team "redabot's" ball launcher scuffs-up the balls enough to not function properly with team "bluabot's" mechanism?
There can only be a modest amount of ball inspection and that could only possibly take place in-between matches.
Rules on accidentally or intentionally messing-up the balls?
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 09-01-2006, 13:08
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I'd guess that FIRST will not try to inspect balls for damage to surface finish, scuffs, scratches, and so forth. Between matches they may try to replace balls that have chunks missing.
Generally, has GDC has expected teams to design gamepiece interaction mechanisms that are robust enough to deal will minor variations in gamepieces. <G20> doesn't explicitly mention balls -- that is probably not an omission by the GDC.
Richard Wallace
since 2003
Unread 09-01-2006, 13:32
We talked about this at our local kick-off event. We decided two things:
- A ball scores if at least 50% of its mass gets through the goal.
- Using 36 grit belts to launch the balls would be a Bad Thing.
The AC-powered test unit is using 150 grit sanding belts.
Unread 09-01-2006, 14:04
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
not to sound negative, but i think the first FIRST ball launcher was revealed in 2002 when the CIM motor was introduced to teams....but back to the post....was the orientation you have it in now the way you tested firing, or did you use any kind of angle on it??
as far as getting the balls dirty or scuffed....no need to use a belt sander for that....did you all see the balls in 2002 after competitions? they got scuffed and marked on their own, and i would plan on have "minor variations" in game pieces because what i remember the balls in 2002 started almost sticky, but by the end of the competition they were very smooth from all the dirt that accumulated.
Unread 09-01-2006, 14:21
Well, you're the enemy of fun, aren't you?
The gray toolbox in the pic is a crucial part of the elevation system.
In our highly-sophisticated testing lab (which looks a lot like my garage/shop), the balls collect dirt better than a Swiffer duster. I'd make sure all the ball-handling surfaces you use have a really high coefficient of friction. I'm seriously thinking of using 1-inch sanding belts in competition.
Unread 09-01-2006, 15:28
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Aaaaaactually...
The first, FIRST ball launcher was unveiled in 1994 on the famous Sunny Delight robot. This robot went on to win the National Championship that year.
-JV
Unread 09-01-2006, 15:47
dhitchco's Avatar
Awards/Photo/Video &quot;wizard&quot;
AKA: Doug Hitchcock
I can't wait for a sandpaper-powered ball launcher to get stuck and go up in flames.....Ah, the smell of melting Poof balls.
Hey, each team needs a safety officer. Sounds like 'bot carts should carry a manditory fire extinguisher.
Either that or an "air raid siren" for incoming ejected high-velocity Poof balls....
Unread 10-01-2006, 14:19
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
Originally Posted by JVN
Aaaaaactually...
-JV
We still have that machine running! Although until Saturday it was in storage...
ID:	3794  Click image for larger version
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 10-01-2006, 17:51
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
pic i posted in 2002, of the launcher.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 10-01-2006, 20:26
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
2 questions...
1 - how much surface damage is that doing to the ball?
2 - how fast is that shooting?
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 10-01-2006, 21:02
DonRotolo's Avatar
Back to humble
FRC #0832
Very nice! But, I think the thread title should at least be second FIRST ball launcher*, seeing as how This Post appeared on Sunday...
*for 2006
Don
Unread 10-01-2006, 22:41
The one in the pic above was also finished on Sunday, I just didn't take pics until Monday. Tie?
Unread 10-01-2006, 22:42
Originally Posted by Heretic121
2 questions...
1 - Essentially none. The sandpaper is fine grit.
2 - About 5 m/sec. Sanders have LOTS of torque, but they don't run super-high belt speeds.
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
Low quality 2X ball? Rob General Forum 16 22-04-2004 22:36
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
