Go to Post FIRST describes this program as students working "side by side" with professional mentors. We describe our team as working "shoulder to shoulder." Maximum learning happens with maximum interaction between students and mentors, whenever and wherever that may be. - jspatz1 [more]
Unread 10-01-2006, 10:19
insub2 insub2 is offline
None #1227
insub2 is an unknown quantity at this point
Re: What is the hardest (yet possible) task in this year's game?
Originally Posted by Donut
I thought the goal would want to be autonomous again... if not, I agree it should be firing the ball in while moving. But why keep it that simple? They should also have to shoot it from their own end of the field, so it's a half-field shot at least.
i think (if i recall are math from lastnight's meeting) the farthest away you can be with the limit of 12m/s and still make the shot (no wind resistance) is about the halfway line. maybe a little more but no much.
Unread 10-01-2006, 10:41
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Originally Posted by Billfred
The thing is, is that really possible? Can any alliance shoot all thirty balls into the center goal in ten seconds? My gut instinct says you won't see that happen. Ten, though, is entirely possible.
30 shots at the same 30 inch space in ten seconds seems like a midair collision to me. I agree with Billfred it just doesn't seem possible.
I actually have difficulty believing 10 in 10 seconds is possible without violating 12m/s with the first few shots.
Unread 10-01-2006, 13:13
Anyone that scores on the high goal while moving parallel to the plane of the goal while moving at least 5 fps. We aren't even going to try...
You could make this even more challenging by making it the first team to score more than five times per match using the above conditions.
Unread 10-01-2006, 13:20
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Human scoring will be harder than it might seem. We mocked up something last night and practiced to see how easy or hard it will be and I'll be surprised if anyone can score 10 consecutively. Scoring is achievable - consecutively 10 times in a row will be a challenge from that distance and with robots running around.
Unread 10-01-2006, 13:23
with a spinning wheel shooter you can launch balls as fast as you can hopper them into the input side
Ive personally seen a soccer ball shooter like this that launched them about 40 feet, and if you fed it fast enough you could have several balls IN THE AIR at the same time. It literally fired a stream of soccer balls.
One problem with this (I mentioned in another thread) the wheels do slow down when you fire a ball, so you either need a powerful motor to spool them back up between shots, or you need a big flywheel.
Unread 10-01-2006, 14:52
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Originally Posted by Andrew Blair
Hmm... Maybe put all 10 balls though the cnter goal in less than, say, 7 seconds?
Being realistic, I'd say that that's impossible.
If you were to somehow design an /incredibly/ accurate robot who could make 75% of its shots, you would still have to fire off fifteen shots in 6.8 seconds (less than 7) or 2.205 balls per second. And 75% is not realistic for an acuracy measure.
I would say a challenge could be to:
carry x balls (suggestion: 35-40)
make y% accuracy with a shooter(suggestion: 70%) (within some reasonable amount of time, though not really timed)
Unread 10-01-2006, 15:31
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
What about scoring on your goal from the platform below it? There was lots of debate how this would never work before.
Unread 10-01-2006, 15:45
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
Personally, I'm going to be looking for these two things. I bet they're even feasible.
1) One robot scoring all 10 balls to the center during autonomous.
2) A robot with a completely automated vision and aiming system, who can score >10 consecutive balls to the center during _human_ player mode. And I'd want to see these shots taken from at least a few different places on the field.
Unread 10-01-2006, 15:50
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #6721 (Trailblazer Robotics)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
Originally Posted by donut
How about put all 10 balls in the center goal in autonomous, without using a dead reckoning system?
I second that objective (notice i bolded and underlined "without" using a dead reckoning system).
First team to do it wins.
Let the games begin.
have no fear of perfection, you will never reach it.
-Salvador Dali
Unread 10-01-2006, 16:06
Best Available Data
FRC #1778 (Chill Out!)
I'd agree with that one. We measured the distance, and it was really far. I doubt someone could make 5 consecutive shots even without the wall in front of them.
Unread 10-01-2006, 17:17
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
I'd say hitting the goal on the move, when not moving either parallel or perpendicular to the goal, so at some other angle than dead on or straight across as those are easy to account for, but when you not only change distance to the goal but also angle to it, thats tough, we thought about it, and it turns into such a painful calculation, it's probably one of the hardest feats in this game, whether in autonomous or in human mode.
Unread 10-01-2006, 19:37
Andrew Blair's Avatar
FRC #0306 (CRT)
Okay, couple things wrong here. First of all, assuming an autonomous challenge, you could, by yourself, only shoot ten balls. Now, That is a ball every 7/10 of a second, which (look at you watch) is not that short a period using a flywheel to throw them. Now, the challenge assumes that you SHOOT the balls in 7 seconds, so you get three second grace period to find and lock onto the target. Sounds pretty possible to me, especially if you did it without moving from your starting position.
-Sir Francis Bacon
-Albert Einstein
Unread 10-01-2006, 20:52
Best Available Data
I think you guys aren't taking everything into account when you say that 10 balls in 7 seconds is impossible. What about a 2 or even scarier 4 barrel launcher! We'd see some fast scoring.
Unread 10-01-2006, 21:01
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
well, i think the hardest thing to do this year would be to block the center goal shots...our team figured out one of the very VERY FEW ways to do it legally....but we couldnt do it due to power issues... , i was looking forward to it
Min-Max to the Max!
Unread 10-01-2006, 21:06
for a little persepective on this, the max airspeed of the ball is 12 meters per second
if you fire balls at one second intervals they will be 12 meters apart in flight
thats ~40 feet apart. in the world of launched projectiles that is a HUGE space
I can visulalize balls flying through the air 2 meters apart, and all going in the goal - at 12 m/s that 10 balls in 1.66 seconds!
Its very easy to get tunnel vision, and only think of the problem in terms of what a human being can do
we need to think of this in terms of what a machine can do. A machine with a computerized targeting system, and 2HP at its disposal.
Infared in Next Year's Game Paradox1350 Rumor Mill 45 02-04-2004 20:45
The key to this year's game (long) archiver 2001 6 23-06-2002 23:05
do you like this years game archiver 2001 8 23-06-2002 22:29
Next Years Game Ben Rumor Mill 24 01-08-2001 09:04
How was this years game compared to others? Anthony S. General Forum 7 13-06-2001 15:43
