Re: Anybody build the given 2006 Transmission
Umm...Hmmm. Grinding is bad. If you can, lube them up real well and run them for like 20 minutes. All gearboxes need to wear in. But if it's a really, really bad grinding noise, somethings wrong. They are not silent by any means, but grinding shouldn't happen.
just wondering if it would work. But if you take an old KOP tranny and seal it up with a gasget on front and seal all the bearings in it( flanged bearings on gasgets?) would it work fine to run it in transmission fluid or sorthing of the sort? like for an off-season project.
I see in the robot part of the manual that we can use up to four "small CIM motors. Does this mean we can use four transmssions too? |
Unless you need a lot of extra weight, I think just having 2 transmissions should be fine for a tank drive robot, unless you're planning on having a holonomic with the 4 transmissions in the corners driving 4 omniwheels independently. Last edited by Jeff K. : 11-01-2006 at 00:34. |
| Where do you actually build your robot and who does the building??? | Elgin Clock | General Forum | 47 | 14-11-2006 17:50 |
| [Official 2006 Game Design] OK, so YOU design the 2006 game... | dlavery | FRC Game Design | 29 | 08-01-2006 00:21 |
| Is a shifting transmission really necessary? | Jay TenBrink | Technical Discussion | 78 | 02-08-2005 09:21 |
| OCCRA Teams - where do you build? | Phil 33 | OCCRA | 7 | 28-10-2004 21:41 |
