Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
Unread 10-01-2006, 13:29
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Human players scoring
I read the rules but didn't see if the Human players scoring is also limited to "only when the alliance is offense" or can they score when the alliance is also on defense?
I suppose the air will be filled with flying balls at the end of each match as humans will be throwing everything they have before time runs out - and with most teams trying to get on the ramp it will probably be as good a time as any for a clear shot at the corner goals.
Once enough missed balls are scattered about, the probability of not hitting a ball on the ground will be pretty low, but it will be fun to see all those balls flying about.
Unread 10-01-2006, 13:32
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Human players scoring
I believe when the alliance is on defense, their goals are turned off so any ball is (intentionally or otherwise) scored, it is not counted.
When the green light above those goals is lit, those goals are active.
4.2.2A match is 2 minutes and 10 seconds long. An AUTONOMOUS PERIOD starts the match, which lasts 10 seconds. Following AUTONOMOUS PERIOD, there are 2 minutes of tele-operated game play, which are broken up into three 40-second periods. There may be a short pause between AUTONOMOUS PERIOD and the start of the tele-operated periods as the players stations are activated. The SECOND PERIOD and THIRD PERIOD are offense/defense, where only one ALLIANCE can score. During the FINAL PERIOD, both ALLIANCEs can score.
<G02> SECOND PERIOD - The ALLIANCE with the highest score at the end of AUTONOMOUS PERIOD will play on defense during the SECOND PERIOD. In the event of a tie at the end of AUTONOMOUS PERIOD, the ALLIANCE playing on defense during SECOND PERIOD will be chosen at random. Any balls scored in the defensive ALLIANCE’s goals (opposite their DRIVER’s station) during this period will not be counted.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 10-01-2006, 13:34
It's in Section 4 - The Game
Originally Posted by <G02>,<G03>
...Any balls scored in the defensive ALLIANCE's goals...will not be counted.
Unread 10-01-2006, 21:37
DonRotolo's Avatar
Back to humble
FRC #0832
And they'll have to throw it with everything they have. Almost 60 feet is kinda hard with a Poof ball, and after the second bounce any possible accuracy is lost (the balls roll funny, they are unbalanced).
Don
Unread 10-01-2006, 22:48
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Its gonna be rare for an HP to make a 54 foot shot over a 6 foot wall into a 10" goal with a 7" in ball, but it wont cost ya at the end of matches to try for it.
Unread 10-01-2006, 23:37
volunteer helper
FRC #6099 (Knights)
Thanks for the clarification on the scoring - Alliance does mean both robot and human, and the scoring only when the green light is on does indeed make sense.
Just to let ya know, we mocked up a goal and tried out throwing the ball 60 feet or more to observe the dynamics. Man o man, that is a long throw but with alot of practice I believe that the humans will score - as long as the path is clear and they can settle the ball into a rolling motion rather than a bouncing one.
It's gonna be really hard to practice in an environment that allows the diagonal throw - all we could come up with is a long narrow corridor and the darn ceiling kept getting in the way!
Unread 10-01-2006, 23:58
volunteer helper
FRC #6099 (Knights)
Shu,
They may very well be throwing at the center goal by mistake - but I'm certain that the outcome of th match won't change because the humans cannot score in the middle goal (the balls don't count if thrown in by a human) - humans can ONLY score in the lower goals - but I'm sure some of them will get confused and excited at the end and they may try throwing at it.
Unread 11-01-2006, 00:17
... but I'm certain that the outcome of th match won't change because the humans cannot score in the middle goal (the balls don't count if thrown in by a human) - humans can ONLY score in the lower goals
Actually, IF a human makes it into the center, it costs the alliance 5 points per ball, for a net gain of -2 points per ball that makes it.
Unread 11-01-2006, 09:09
Originally Posted by Shu Song
I just know that a few matches will be decided with human players hurling balls at the center goal at the end of the match.
If that turns out to be the case, the human player responsible will find him/herself to be suddenly very unpopular. (A ball scored in the center goal by a human player earns the alliance a five point penalty.)
Unread 11-01-2006, 13:02
Ashley Christine's Avatar
Ashley Christine Ashley Christine is offline
FRC #1511
Ashley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond repute
I guess you gotta start training your human players early... get them to get those long low shots in.
Good luck to all of this years human players.
Otherwise, leave it to the bot to score.
Unread 11-01-2006, 13:07
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Not quite accurate. The ball does not count and there is a 5 point penalty. Therefore -5 points.
We do not stop playing because we grow old;
we grow old because we stop playing.
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video &quot;wizard&quot;
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Watch out guys!
Ashley is a dodgeball champion and can nail the lower goals without even bouncing the ball off the floor.....he, he, he
By the way, here's a good math question:
If the robot can only toss the ball at a max. of 12 meters per second and that results in about a 35 foot trajectory, then how fast does a human player have to toss the ball to make it all the way to the other end of the field and score in a lower "mouse hole" without bouncing along the floor?
And, the human player has to do all that while getting high enough to get his/her arm over the wall....wow..
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 11-01-2006, 13:16
FRC #1511
Now I wish that I was on one of those teams that happens to have some oddly tall 7 ft person. Anyone of that description want to join my team?
Unread 11-01-2006, 16:50
MChapman MChapman is offline
AKA: Mellie
FRC #0176 (Aces High)
MChapman is just really niceMChapman is just really niceMChapman is just really niceMChapman is just really niceMChapman is just really nice
I'd say human players definently should train, myself included. I may be human player this year an i'm short, so i'm gonna need my practice.
Unread 12-01-2006, 23:38
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
<G33> HUMAN PLAYER Shooting Zone - The HUMAN PLAYER must remain behind the STARTING LINE
and within the ALLIANCE ZONE when they are entering a ball onto the field. Each violation will result
in a 5-point penalty.
Is the human player allowed to reach over this line, but not step over it, or not break the plane at all.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
A Warning to Human Players for safety's sake. Elgin Clock General Forum 30 05-04-2005 04:30
Are you planning to use your Human Players? Swampdude Rules/Strategy 23 09-02-2005 19:37
[FVG]: Human Players Round 3 Mike Ciance FIRST-related Organizations 6 29-06-2004 05:52
[FVG]: Human Players Mike Ciance FIRST-related Organizations 6 21-06-2004 21:34
