Go to Post step it up, stop trying to validate mediocrity - Aren_Hill [more]
Unread 10-01-2006, 21:49
Masterfork's Avatar
Masterfork Masterfork is offline
Joshua Hunnings
AKA: Fork
FRC #0233 (the pink team)
Masterfork is a jewel in the roughMasterfork is a jewel in the roughMasterfork is a jewel in the rough
Send a message via AIM to Masterfork Send a message via MSN to Masterfork
Talking Re: Best Way to Shoot the Balls??
Originally Posted by sciguy125
I was thinking about rifling also. The main problem with putting groves in the barrel is that it would either cut up the ball or simply slow it down too much. I was thinking about adding a set of rotational wheels. If there's a set of wheels mounted perpendicular to the "launching" wheels, it could spin the ball. You'd probably have to use a set of omniwheels though. You'd also have to make sure that the barrel is relatively low-friction.
For a little bit today, we were considering a gatling gun style device. Had it not been discounted for impracticality, it would have been pretty cool.
LOL WELL WE LOOKED AT rifling but the thing is it is to complex but if u are trying to get a spin on the ball of that sort try doing what some paintball barrels do. which would be cut holes in a spiral sequences around the barral to let the air flow give it some spin, that was one way i could imagine doing it farely but rifling it by cutting or putting grooves would slow it down tramendously but that is what happens in a gun. i would also imagine that actual rifling would cut up the ball. also one way could be to sort of making a slight elavation in the inside surface of the barrel and spiral it to do the spinning. something I would also like to say is that it would prolly be a waste of supplies and time to try to rifle it becuase the rifling works so well with a real gun is because the bullet is actaully sealing the barrelfrom the charge so it can use the propulsion of the powder or gas made by it and grip the grooves of the barrel . which means applying it to this game would mean those balls would have to be a tight fit to grip the rifling or spin as well as a bullet.
and shooting balls with rifling well at least when i muzzle load with lead balls the rifling makes the balls rise(not curve it stays on a straight path it just rises at a distance) to a small extent at like 50 yds on a muzzleloader but very acurate still just keep that in mind if u found a way to impliment it because it might be affected in the same waybut if successful please tell me how because i would really like to see how that would work and how well it would too but i would not recommend the waste of time it might involve
2007 World Championship Finalist thank you 71 and 179
2007 Archimedes undefeated Champions thanks 179 and 71
2007 Florida regional semifinalist thanks 180 and 1889
2007 Florida regional Spirit Award
2006 Archimedes Division Finalist
2006 Boston Champions
2005 UCF Regional champions thanks 1592 and 179
2005 Colorado Regional champions thanks 118 and 935
2005 Colorado Regional Chairmans Award
IRI 2005 - Champion thanks to 33 and 868 - it was a GREAT event
2005 World Championship - GM Industrial Design
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
