Go to Post Woody, If there is any chance your reading this ... you've changed my life. - Gope [more]
  #31   Spotlight this post!
Unread 09-01-2006, 07:45
Cyber Punk 234's Avatar
Cyber Punk 234 Cyber Punk 234 is offline
John Carter
AKA: John
None #0234 (Cyber Blue)
Team Role: Webmaster
Cyber Punk 234 is on a distinguished road
Send a message via AIM to Cyber Punk 234 Send a message via MSN to Cyber Punk 234
Re: Best Way to Shoot the Balls??
Truly Im not 100% sure but I cant wait to build.
  #32   Spotlight this post!
Unread 09-01-2006, 07:55
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
During our brainstorming session yesterday we came up with a few ideas as to how to shoot the ball.
However, there was one that we came up with that I just can't see working. We thought of using a spring, sorta like a pinball machine, and having a winch pull it back. I just see this being extremely slow, needing a long pull length and not being consistent unless we use a hookean spring.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
  #33   Spotlight this post!
Unread 09-01-2006, 15:04
ben281's Avatar
ben281 ben281 is offline
Ben 281
AKA: Ben Grier
#0281 (EnTech)
Team Role: Student
ben281 will become famous soon enough
Send a message via AIM to ben281
yes, you are correct. a spring would require many mechanisms to get it to work, including a pull back and releasing mechanism, along with a way to load the balls. also springs do not scale up well. if we were shooting pinball balls it would be much more feasable.
  #34   Spotlight this post!
Unread 09-01-2006, 15:33
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
I am no engineer and I certainly am not a ballistics expert, so correct me if I am wrong here. . . .
Rifiling works excellently to stabilize the flight of a cylindrical object like a bullet or missile but would it not cause a spherical object like a Poof-Slinky ball to curve? Somehow that doesn't sound like it would be more accurate to me.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
  #35   Spotlight this post!
Unread 10-01-2006, 21:49
Masterfork's Avatar
Masterfork Masterfork is offline
Joshua Hunnings
AKA: Fork
FRC #0233 (the pink team)
Masterfork is a jewel in the roughMasterfork is a jewel in the roughMasterfork is a jewel in the rough
Send a message via AIM to Masterfork Send a message via MSN to Masterfork
Talking Re: Best Way to Shoot the Balls??
Originally Posted by sciguy125
I was thinking about rifling also. The main problem with putting groves in the barrel is that it would either cut up the ball or simply slow it down too much. I was thinking about adding a set of rotational wheels. If there's a set of wheels mounted perpendicular to the "launching" wheels, it could spin the ball. You'd probably have to use a set of omniwheels though. You'd also have to make sure that the barrel is relatively low-friction.
For a little bit today, we were considering a gatling gun style device. Had it not been discounted for impracticality, it would have been pretty cool.
LOL WELL WE LOOKED AT rifling but the thing is it is to complex but if u are trying to get a spin on the ball of that sort try doing what some paintball barrels do. which would be cut holes in a spiral sequences around the barral to let the air flow give it some spin, that was one way i could imagine doing it farely but rifling it by cutting or putting grooves would slow it down tramendously but that is what happens in a gun. i would also imagine that actual rifling would cut up the ball. also one way could be to sort of making a slight elavation in the inside surface of the barrel and spiral it to do the spinning. something I would also like to say is that it would prolly be a waste of supplies and time to try to rifle it becuase the rifling works so well with a real gun is because the bullet is actaully sealing the barrelfrom the charge so it can use the propulsion of the powder or gas made by it and grip the grooves of the barrel . which means applying it to this game would mean those balls would have to be a tight fit to grip the rifling or spin as well as a bullet.
and shooting balls with rifling well at least when i muzzle load with lead balls the rifling makes the balls rise(not curve it stays on a straight path it just rises at a distance) to a small extent at like 50 yds on a muzzleloader but very acurate still just keep that in mind if u found a way to impliment it because it might be affected in the same waybut if successful please tell me how because i would really like to see how that would work and how well it would too but i would not recommend the waste of time it might involve
2007 World Championship Finalist thank you 71 and 179
2007 Archimedes undefeated Champions thanks 179 and 71
2007 Florida regional semifinalist thanks 180 and 1889
2007 Florida regional Spirit Award
2006 Archimedes Division Finalist
2006 Boston Champions
2005 UCF Regional champions thanks 1592 and 179
2005 Colorado Regional champions thanks 118 and 935
2005 Colorado Regional Chairmans Award
IRI 2005 - Champion thanks to 33 and 868 - it was a GREAT event
2005 World Championship - GM Industrial Design
  #36   Spotlight this post!
Unread 10-01-2006, 21:54
Masterfork's Avatar
Joshua Hunnings
AKA: Fork
and u have to take in to play the rule about stored energy cus we were thinking along those lines and just think of how much energy it would use to pull the spring back in a match and how many times during it too, to be affective
sorry about the 2 posts in a row
just found a new thing to comment sorry
  #37   Spotlight this post!
Unread 10-01-2006, 22:29
Kevin_547 Kevin_547 is offline
FRC #0547
Kevin_547 is an unknown quantity at this point
it seems that most ppl are toying with the softball pitcher idea to shoot that balls. which i think is a very good way of doing so but how is everyone thinking how u are going to get the balls from ur holding area to the wheel to shoot without over loading ur gun or shooter or w/e u want to call it.
  #38   Spotlight this post!
Unread 10-01-2006, 22:32
That remains to be figured out, assuming teams use a holding area. One of our engineers had an idea, but what that is is a secret.
  #39   Spotlight this post!
Unread 10-01-2006, 22:35
Masterfork's Avatar
Joshua Hunnings
AKA: Fork
well that is what peoples creativity comes in which will be interesting
  #40   Spotlight this post!
Unread 10-01-2006, 22:57
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
my dad had some awesome ideas. I just wonder about jamming. Is it possible that a pile of balls may interfere with each other's ability to load? Kind of like how 2 balls may get stuck in a funnel and neither actually falls into the hole that is designed to fit one? If that is unclear, sorry I'm not the best person at explaining things.
Is probably best for the shooters if the balls are stored single file to prevent jamming. Boy, I want to go present all my ideas to my old school's team, but as an alumni(us) (which is singular?) I want to leave all the creativity to the students. I just hope they ask me for ideas =).
BTW.
if anybody does not want to use baseball-style guns to fire, I experimented with a scaled down catapult made out of lego. It uses a couple elastics (the more elastics/springs, the more stored energy), to store energy, and the accuracy is surprisingly good. I was able to score little blocks of lego in the 1 foot diametre lego basket from approximately 2 metres away at nearly 100% accuracy. However, there was some awesome recoil from that thing.
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
  #41   Spotlight this post!
Unread 10-01-2006, 23:00
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #6721 (Trailblazer Robotics)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
Is there a limit to the amount of force we are allowed to have stored in a spring on the robot? or does the projection of the ball by that method just have to follow the 12m/s rule?
have no fear of perfection, you will never reach it.
-Salvador Dali
  #42   Spotlight this post!
Unread 10-01-2006, 23:13
WebWader125
Posts: n/a
Re: Best Way to Shoot the Balls (Power?)
Has anyone figured out how much power it will take to keep a softball-style shooter going? Seems like all that freewheeling would kill the battery.
  #43   Spotlight this post!
Unread 10-01-2006, 23:29
Masterfork's Avatar
Joshua Hunnings
AKA: Fork
we thought about that but u have to put in to thought that once u get it going the momentum is what will save the battery life because it will take less energy to keep it going
  #44   Spotlight this post!
Unread 11-01-2006, 01:46
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Flywheel and a good PID will prevent your motor from overworking. Its not that bad. And, just shut it off if you're not using it =)
My question is, is 12m/s muzzle velocity? if so, if we move the entire launcher assembly by some v, we'll have a ball traveling > 12 m/s but with a muzzle velocity of < 12 m/s..
  #45   Spotlight this post!
Unread 11-01-2006, 12:42
insub2 insub2 is offline
None #1227
insub2 is an unknown quantity at this point
it is possible to have two balls jam. the teams will just have to design a way around that. stored single file, yes, or a take a field trip to some factories. i did some temp work on an assembly line one summer and was amazed by all the machines used to move things around. a few that come to mind as aplicable would be a pinwheel on the bottom of the hopper to break up jams if they were to occur or a slowly contracting space (like a funnel but with steeper sides).
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
