Let's swap data!
Unread 10-01-2006, 22:43
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
Interupts?
I was told that there was a really good paper in interupts. Could anyone point me to that?
Also, any docu about how to use/write to EEPROM would be much appriciated!
Ultamently i want to create a command line interface for my robot. This will be complete with the ability to tweak settings and perhaps script autonomous code on the fly. A status screen would also be very nice but for that i would need to understand how VT100 works.
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 10-01-2006, 22:45
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Interupts?
http://kevin.org/frc/
Unread 10-01-2006, 23:11
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Interupts?
I have EEPROM code that works with the robot controllers. A version that will work with the 2004/2005 controllers can be found here: http://kevin.org/frc/2005/. I'll release a version for the 2006 controller soon (It's done, but I want to do some testing).
Well, the new camera menuing code should give you some ideas.
From camera_readme.txt:
Since the IFI terminal is somewhat restrictive, you might
consider using one of the free high quality terminal emulators
available. TeraTerm Pro (http://www.ayera.com/teraterm) and
PuTTY (http://www.chiark.greenend.org.uk/~sgtatham/putty) are
a few examples. If you dive into the existing code or create
your own custom menus (as I hope you will), you might consider
writing code that will exploit the capabilities of a good
terminal emulator. To get started, do a google search on the
phrase "terminal escape codes".
-Kevin
Kevin Watson
http://kevin.org
Unread 10-01-2006, 23:19
Validius's Avatar
AKA: Mark Ratering
Re: Interupts?
Yes, teraterm is a must. The IFI terminal is kinda lame.
Kevin: Have you written any docu on interupts?
-Peggy Noonan
Unread 10-01-2006, 23:31
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Interupts?
Maybe you're referring to this one, Interrupts for Dummies.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 10-01-2006, 23:33
FRC #2429
Re: Interupts?
No, but Dan Katanski did some time back. Here's a link: http://www.chiefdelphi.com/forums/pa...le&paperid=272.
You'll find my interrupt template code for the 2004/2005 controller here: http://kevin.org/frc/2005. It should work just fine with the 2006 controller, but I haven't tried compiling interrupts.c/.h for the new controller so your mileage may vary.
-Kevin
Kevin Watson
http://kevin.org
Unread 11-01-2006, 18:29
Validius's Avatar
AKA: Mark Ratering
Re: Interupts?
Thanks, all that looks great!
-Peggy Noonan
Need interupts help, and another question... Kevin Karan Programming 7 22-02-2004 11:20
