Re: pneumatic launch velocity
but if you use an arm to extend the distance (And velocity) of the ball it will shoot a lot more. i had a phyz project that had size limits of 25cm high x 50cm long and i was able to shoot a tennis ball 10meters using a simple lever arm with 2 3/4 bore i think 6in stroke cylinders at initial 100psi with 4 FIRST tanks. with small sling arm.... sling arm would be cool but quite hard to reload in our robot's case tho |
dont say no too quickly
the problem with using a pneumatic cylinder to launch things is the small size of the tubing and valves. You cant get a fast enough inrush of air to move the cylinder piston as fast as you need to but dont give up, there are ways around this one would be to rig up a stop, or trigger/release pin about halfway down the cylinders length. To shoot something you would pressurize the cylinder against the trigger pin. That will build up a volume of air inside the cylinder at 60PSI then you pull the trigger out of the way. There will be nothing to slow down its movement this way, except the ball that is being launched. I must point out, these cylinders are not designed to be slammed into their own ends, so if you do something like this you must put a mechanical bumper or stop that limits the motion of the piston, so it cannot slam the end internally. If not, sooner or later the end will blow out of the cylinder, with a great deal of force: someone could be seriously injured. there are other ways - brainstorm the concept: use the cylinders to load up some other form of energy storage/release mechanism. |
I should add: you would have to leave the fitting out of the far end of the cylinder, or it will restrict the air as it flows out.
this means the cylinder can only be pressurized from one end, so you will need a weak spring to retract it for the next shot. maybe surgical tubing? |
Aside from the actual speed that the piston moves (I hadn't thought about that until now), I don't think that it would be practical to launch the balls this way.
E=0.5mv^2 To get the ball to 12m/s, we need to supply it with 13J. This assumes no spin and minimal friction losses. W=Fd A 2" cylinder at 60psi will be able to give this 13J with a ~6" stroke. That's a huge volume of air. Your fire rate wouldn't be that great. Of course, if your goal isn't the full 12m/s, some pneumatic mechanism might work for you. |
#7
the acceleration is 480M/S^2, and the time to get from 0 to 12m/S is 25mS |
#8
You are over constraining the problem. There is no need to have the piston directly provide the full range of motion required to accelerate the ball. Use a 2" diameter x 1" stroke piston. The piston is connected to a range-multipier lever with a 1:10 ratio. The piston will provide 188 pounds of force over 1" as input to the lever. The end of the lever will travel 10" with 18.8 pounds of force. As noted in Ken's post above, there is more than enough energy here to launch the ball.
-dave |
#9
an 11" lever with the pivot point 1" in from one end will have a 10:1 multiplier
ten times the distance (speed) on one side vs the other, with 1/10th the force available. |
#11
See attached.
#13
Ahhh! what if you were to take that 1" stroke piston 2" diameter and fire it directly to the ball. Would that be enough to fire it to the center goal??
#14
probably, if you have enough pressure in the cylinder
and you preload the cylinder with pressure, and use a mechanical release like I talked about on page one the only caveat, a 1" piston throw may not deform (dent) the ball enough to transfer all the energy quickly. You might need a bowel shaped plate to keep the ball from deforming as the cylinder punches it. a 1" piston throw into a 1:10 lever: definitely! |
#15
wow... Release latches, lever linkages etc.. Yall are making this way too complicated.
| Falcon 1 Ready to Launch Friday 11/25 | Doug G | Chit-Chat | 2 | 26-11-2005 22:04 |
| NASA Schedules Robotic Spacecraft Launch | Mirza95vx | General Forum | 2 | 07-04-2005 00:33 |
| Pneumatic Wheels | Steve P | Pneumatics | 4 | 07-02-2005 15:16 |
| Pneumatic Gripper ruling | Nitroxextreme | Pneumatics | 7 | 30-01-2005 13:04 |
| Who has used pneumatic wheels? | chellyzee93 | Kit & Additional Hardware | 3 | 16-02-2003 11:49 |
