Go to Post There MUST BE room for mistakes. That’s one of the best ways to learn. - Ken Leung [more]
Unread 10-01-2006, 19:04
polyBot polyBot is offline
polyBot is an unknown quantity at this point
Ultrasonic Range Finder
Hi, I was wondering if the minirc from ifirobotics is capable to generate and accept signals to and from an ultrasonic range finder. And if so, how to go about doing so. Please help.
Unread 10-01-2006, 19:16
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Ultrasonic Range Finder
I see no reason why not. It uses PWM just like a full sized RC, all you need is a PWM ultrasonic sensor. I recomend either the VEX sensor or Parallax's.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 10-01-2006, 19:24
Umm Errr...
Well it depends on the rangefinder. I have seen ultrasonic rangefinders that output everything from pwm, to serial data. Specifically what rangefinder are you looking at?
1139 Alumni
Unread 10-01-2006, 19:33
Thanks. Now, I'm having a problem firing and receiving data from the ultrasonic range finder. Currently using srf05 from acroname
:http://www.acroname.com/robotics/parts/R271-SRF05.html
It takes a 40 kHz frequency. How do I generate this using the first default code? And how can I get the PWM signal back? Thanks a lot for help.
Unread 10-01-2006, 19:41
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
You have to use two I/O pins from the mini-RC. One to send a 10uS pulse and the other to listen for an echo. When I find the code for it I'll try to post it. I'm having a difficult time finding an up to date version.
Unread 10-01-2006, 22:58
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Why do you need the range finder?
If it is to find how far from the goal you are then there is an easier method. If you plan on using the CMU cam then have a constant in the program for the height of the light and then just derive the angle from the PWM signal of the servo. THen all you need is to do some trig
Unread 10-01-2006, 23:10
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Having the RC do trig calculations takes up a lot of time and might make the program very slow. Whats most of the time done to get around that is to store a table of essential trig values and just have the RC look the values whenever you need them. Now it becomes an O(1) operation and speeds up the code a lot.
But as you've probably guessed by now, you can't possibly store the sin/cos values of every angle so you must round your angles to the nearest 5 or 10 degrees, adding more error on top of whatever calculation you're already doing.
The ultra sound provides for a more accurate range measurement with minimal error.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 10-01-2006, 23:15
Actually I've been looking at using ultrasonics to detect other robots in autonomous mode and hopefully avoid them. With the field as open as it is and a bunch of robots moving to similar goals the last thing we want is a game of chicken between two blind robots.
Mmmmm more or less.... I don't know if you ever used them in Physics class or not but from playing with them they tend to by pretty finicky.
One, you have to assume their's nothing between you and the wall.
Two, you are facing the wall almost vertically, they don't like angles that much.
Three, that they have the range. The Parallax sensor I referenced had a range of 3.35 meters and that's pretty darn good for a ultrasonic sensor.
I admit I haven't actually used one in a robot application but we use them routinely in our physics class. They tend to be best at hitting a flattish surface at close range.
Unread 11-01-2006, 00:09
Shu Song's Avatar
Melodious Footware
lol, shows you how much I know about this stuff. I believe my team will be taking the trig table approach as we've had trouble with sensors to calibrate in the past. But this ultra sound sensor sounds like it would be just as much a paint to set up as doing the trig for it and compensating for the error.
Unread 11-01-2006, 15:52
When I pulse out (PWM) to the ultrasonic range finder, it seems that the device is firing too rapidly. And how should I go about recieving the signal back. Any ideas?
Unread 11-01-2006, 17:23
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
I'm using the SF04 which is similar.
I start a ping via:
iopin_sonar_out = 1; // start 10us pulse
/* wait 10us, @instruction is 100ns and there are 3 per loop */
/* loop counter = 100/3=33 */
for (counter=33; --counter != 0; ); /* ~10us delay */
iopin_sonar_out = 0; // end pulse
Then you wait for the output (echo) line to go high and time the pulse between going high until going low again. Ours is tied to one of the configurable interrupt lines and captures the system clock time in the interrupt routine at the two echo pulse edges then does the math.
You also have to wait some time between pulses, something like 50ms before you can start another ping.
See http://www.robot-electronics.co.uk/htm/srf05tech.htm for more info.
DCBrown
Unread 11-01-2006, 23:12
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I looked at a few rage finders and the graphs were not linear, wouldn't this propose a problem with having to do extra calculations?
Unread 12-01-2006, 11:53
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
We testing the ultrasonic for EasyC for FRC we found that the Vex Ultrasonic was very good for its size and cost. The unit can measure distance accurately upto 15' away.
Unread 12-01-2006, 18:02
Ok. I've got the ultrasonic range finder firing and returning a signal via PWMs on the miniRC. Now the problem is, the range is only good for about 8 inches, beyond that, it outputs the maximum value (255). What could be the solution here?
Unread 29-01-2006, 09:54
Carpe diem
Polybot, that setup won't work because you need an accurate way to measure the time of the pulse width. Take a look at my SONAR software driver for a solution.
VEX UltraSonic and Encoder SOLD OUT... Chris_Elston Electrical 5 09-01-2006 13:22
Camera Vision Range Muhnki Programming 7 05-02-2005 23:26
Camera Range Finding russell Programming 9 31-01-2005 19:54
Using and Coding an ultrasonic sensor Jaine Perotti General Forum 14 06-08-2004 14:13
Optical range sensor Ben Mitchell Technical Discussion 9 12-01-2002 00:11
