Go to Post ...some of our robots could use a proctologist - Scott Ritchie [more]
Unread 10-01-2006, 23:22
MacFlightSierra MacFlightSierra is offline
FRC #0912 (Iron Lyons)
MacFlightSierra is an unknown quantity at this point
CMU code can't find stdio.h
hey all,
I am trying to compile Kevin Watson's code for the CMU (both the bells and the streamlined give same result), and it cannot locate stdio.h
Error [1027] unable to locate 'stdio.h'
I'm using MPLab 7.20, C18 2.40
anyone had such an error before? any ideas on how to fix it?
thanks, good luck to everybody
Unread 10-01-2006, 23:35
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: CMU code can't find stdio.h
Originally Posted by MacFlightSierra
hey all,
Are you really sure you're using C18 2.40?
-Kevin
Kevin Watson
http://kevin.org
Unread 10-01-2006, 23:45
no kidding, I am. MPLAB-C18-v2_40-win32.exe name of file, right of the CBOT 2006 CD.
I installed it in its default dir C:\mcc18 etc (MPLab didnt like it in any other location)
any chance this can be caused by the location of MPLab (non default)?
thank you Kevin, and everybody else
Unread 11-01-2006, 12:54
You are missing the include file path in your project. It sometimes gets dropped when a project is moved to a new machine or when a new project is created.
In MPLAB
Project -> Build Options -> Project
In the pop-up window look for "Include Path" and set it to
C:\mcc18\h
(or for those of you who didn't use the default install directory for the compile, then browse to wherever it is)
Unread 11-01-2006, 17:00
it worked!
Thank you very much Mark, and good luck
Code Structure, Organization, Division of Labor! dm0ney Programming 3 28-03-2005 23:08
Problem downloading any Camera code zuckie13 Programming 4 07-02-2005 20:32
Pwm 11, 12 and CMU code Chris Bright Programming 3 01-02-2005 19:34
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
