Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
Unread 10-01-2006, 17:03
hpman247 hpman247 is offline
FRC #0977
hpman247 is an unknown quantity at this point
Pros and Cons. Shooting or Rolling
My team wants to settle for rolling the balls in for one point. I want to use the camera and focus on shooting the balls into the goal, but our backup being the ability to roll the balls.
What is your teams primary obkective and what are you pros and cons for whatever you are deciding to do.
Unread 10-01-2006, 17:33
Re: Pros and Cons. Shooting or Rolling
Let's go through this bit by bit.
First off, rolling. Pros: Any bot can do it, provided that said bot can move. Multiple balls at once. Cons: Small balls at least used to have an annoying tendency to send robots to the floor on their backs when someone pushed them. Can be easily blocked. Fewer points per ball.
Second, shooting. Pros: Very hard to block. Could be done semi-automatically. More points per ball. Cons: Hard to aim. Easy to throw off aim. One ball at a time.
Your choice of which to make your primary function (well, involve your team, too.)
Unread 10-01-2006, 21:35
SoccerNerd36 SoccerNerd36 is offline
SoccerNerd36 is on a distinguished road
I would say shooting in the center hoop because an opposing bot could just sit right in front of the corner goals and make you ineffective. Even if you do manage to get some in they're not worth as much and the extra goals probably wouldn't compensate for the fewer points per goal. It is much easier to make a roller but a competitive bot will be able to score in the center goal.
Unread 10-01-2006, 23:41
FRC #0977
Oh of course I will involve my team. I just wish they would involve me. I think that it's too easy with the center goals. Blocking will be amazingly easy and it will be hard to score. But who know, maybe I can make a case to them even though it is abot 10-1 on this.
Unread 10-01-2006, 23:51
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Remeber that you have two robots that will be doing everything they can to get you to miss those shots.
-Paul
Unread 11-01-2006, 00:06
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
Perhaps if you demonstrate the accuracy at which balls can be shot, they would be convinced.
You can also point out that scoring in the corner goals will be giving them balls to load for their robots. If your opponents have a strong firing robot, scoring in the corner goals may just give that robot extra ammunition. I agree rolling is not satisfactory for this game. If your team is worried about accuracy, give your robot the ability to recover balls, so the balls you miss may be retrieved =).
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
Unread 11-01-2006, 00:13
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
Remember that for every three you shoot, only one has to go in to match those three sucessfully put in a corner goal. And assuming you can turn your robot, there are a lot more places to shoot from than there are corner goals, harder to block.
And those 2 you miss you can pick back up and shoot again. If all 3 go in the corner, then that are all gone, and belong to the other team. If they bounce off the wall they are free for enyone.
Unread 11-01-2006, 00:27
insub2 insub2 is offline
None #1227
insub2 is an unknown quantity at this point
they get the balls from the center goal too. it's just that they can at best match the points.
Unread 11-01-2006, 00:37
FRC #0977
I really appreciate you guys thoughts. Im not good at thinking pros and cons without conversing with others so i thank you all greatly.
Unread 11-01-2006, 01:00
MrBamboo MrBamboo is offline
Lead Designer of #1888 (Plano West)
AKA: Fei
FRC #1888 (Sigma F)
MrBamboo is an unknown quantity at this point
Looking at the arena the balls scored in the center goal are also retrieved by the other team.
Also any balls you miss shooting at the center goal is also free game for the other team to pick up. So those cons for a corner goal robot applies just the same for a shooter.
Unread 11-01-2006, 01:04
Cpt_Dave_Lister
Posts: n/a
Just wondering but how will it be amazingly easy to block?
Unread 11-01-2006, 17:25
FRC #0977
Im talking about corner goals. Just place your robot in front of it to block balls. Seems pretty easy to me, at least right now.
Unread 11-01-2006, 17:37
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
yes but that only leaves 1 robot to defend two others who may be shooting. I think that a team that has 3 shooters on it may get a little crowded when all three are trying to aim for the one center goal
http://www.wcsrobotics.com
team 663
team 1493
Unread 11-01-2006, 17:46
FRC #0977
That's very true. I don't know how a team with 3 shooters wil be functional. They would have to have at least one bot try to score in a corner goal. And I think id take one robot on two for shooting then play a zone defense and defend the goal that the other bot is trying to score.
Unread 11-01-2006, 17:55
For blocking the goals, that's easy (assuming 1 or fewer shooters on offense). Park 2 bots in front of the corner goals. If there is more than one shooter, it wouldn't work right.
Pros and cons of electronics boards/boxes RbtGal1351 Electrical 19 20-11-2005 15:01
Motor Placement Pros and Cons Pattie Motors 17 24-01-2005 15:40
Practicing after Ship - pros & cons Natchez General Forum 24 18-01-2005 23:06
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
Buckeye Regional PROS and cons emilywll Regional Competitions 14 18-03-2002 10:04
