Go to Post The Bus includes Free Wifi and 120v Power (the bare essentials for any robotics team member) - Clinton Bolinger [more]
Unread 10-01-2006, 22:15
Keeler836 Keeler836 is offline
FRC #0836
Keeler836 is an unknown quantity at this point
pneumatic launch velocity
I was wondering if anyone knew the velocity that a pneumatic cylinder would actuate at, I was thinking of using one on this years robot but i dont know if it would produce the necessary velocity to launch the balls as far as we would like.
Unread 10-01-2006, 22:57
occra 23.
AKA: ryo
None #1481
Re: pneumatic launch velocity
i dunno the numbers but no. i tried with a 3/4 bore cylinder with 4 FIRST tanks at 100psi and a tennis ball but it only launched it a couple feet at best.
but if you use an arm to extend the distance (And velocity) of the ball it will shoot a lot more. i had a phyz project that had size limits of 25cm high x 50cm long and i was able to shoot a tennis ball 10meters using a simple lever arm with 2 3/4 bore i think 6in stroke cylinders at initial 100psi with 4 FIRST tanks. with small sling arm.... sling arm would be cool but quite hard to reload in our robot's case tho
Unread 11-01-2006, 00:29
dont say no too quickly
the problem with using a pneumatic cylinder to launch things is the small size of the tubing and valves. You cant get a fast enough inrush of air to move the cylinder piston as fast as you need to
but dont give up, there are ways around this
one would be to rig up a stop, or trigger/release pin about halfway down the cylinders length. To shoot something you would pressurize the cylinder against the trigger pin. That will build up a volume of air inside the cylinder at 60PSI
then you pull the trigger out of the way. There will be nothing to slow down its movement this way, except the ball that is being launched.
I must point out, these cylinders are not designed to be slammed into their own ends, so if you do something like this you must put a mechanical bumper or stop that limits the motion of the piston, so it cannot slam the end internally. If not, sooner or later the end will blow out of the cylinder, with a great deal of force: someone could be seriously injured.
there are other ways - brainstorm the concept: use the cylinders to load up some other form of energy storage/release mechanism.
Unread 11-01-2006, 00:41
Umm Errr...
Of course, BIMBA does make cylinders with two types of internal bumpers so that they can tolerate this sort of use, but FIRST does not allow the. With some trickery we have gotten a ball to a cylinder to launch a ball at 8m/s, with plans to go higher in an entirely FIRST legal setup. It can be done.
1139 Alumni
Unread 11-01-2006, 00:43
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Aside from the actual speed that the piston moves (I hadn't thought about that until now), I don't think that it would be practical to launch the balls this way.
E=0.5mv^2
To get the ball to 12m/s, we need to supply it with 13J. This assumes no spin and minimal friction losses.
W=Fd
A 2" cylinder at 60psi will be able to give this 13J with a ~6" stroke. That's a huge volume of air. Your fire rate wouldn't be that great.
Of course, if your goal isn't the full 12m/s, some pneumatic mechanism might work for you.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 11-01-2006, 00:45
I should add: you would have to leave the fitting out of the far end of the cylinder, or it will restrict the air as it flows out.
this means the cylinder can only be pressurized from one end, so you will need a weak spring to retract it for the next shot. maybe surgical tubing?
Unread 11-01-2006, 01:06
E=0.5mv^2
W=Fd
using F=M*A and V=A*t my calculations indicate you only need 19 lbs of force over a distance of 6" to accelerate a 0.175 kg ball up to 12m/s
the acceleration is 480M/S^2, and the time to get from 0 to 12m/S is 25mS
Unread 11-01-2006, 09:07
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
You are over constraining the problem. There is no need to have the piston directly provide the full range of motion required to accelerate the ball. Use a 2" diameter x 1" stroke piston. The piston is connected to a range-multipier lever with a 1:10 ratio. The piston will provide 188 pounds of force over 1" as input to the lever. The end of the lever will travel 10" with 18.8 pounds of force. As noted in Ken's post above, there is more than enough energy here to launch the ball.
-dave
Unread 11-01-2006, 09:47
Electrical Engineer
AKA: Phil Baltar
FRC #1351
There's something wrong here. All the equations make sense. However, the solutions that use said equations don't. Actually...nevermind, in the middle of writing this post I found the descrepency.
Ken's solution:
F=ma => a=F/m
19lb = 84.5N
a= 84.5/0.175 = 480m/s^2
V=at => t=V/a
t = 12/480 = 0.025ms
d=0.5at^2
d = 0.5*480*0.000625 = 0.15m = 59"
You missed a decimal place in your conversion from meters to inches.
The problem that I initially found was that 19lb (84N) over a distance of 6" (15cm) only supplies 1.26J. I was surprised I didn't notice that it was exactly 1/10 what it should have been.
Version: 3.12
Unread 11-01-2006, 10:31
There's d = 0.5*480*0.000625 = 0.15m = 59"
ummmm... who missed a decimal?
0.15 meters = 59 inches?
so 1 meter = 32 feet?!
0.15 meters = 5.9 inches (what I said the first time :^)
(32 is the difference between slugs and pounds: pounds = force, and slugs = mass)
Unread 11-01-2006, 11:32
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Oops, sorry. Lesson learned: no physics between 10pm and 7am.
Version: 3.12
Unread 11-01-2006, 20:26
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Not a good excuse for school .. Teachers don't buy that anymore..
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 11-01-2006, 21:51
occra 23.
AKA: ryo
None #1481
nah. have the next ball push it back.
Unread 16-01-2006, 16:58
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
-dave
What is a range-multipier lever with a 1:10 ratio???? what do you mean?
Callsign: N6ARA
Unread 16-01-2006, 17:17
an 11" lever with the pivot point 1" in from one end will have a 10:1 multiplier
ten times the distance (speed) on one side vs the other, with 1/10th the force available.
Falcon 1 Ready to Launch Friday 11/25 Doug G Chit-Chat 2 26-11-2005 22:04
NASA Schedules Robotic Spacecraft Launch Mirza95vx General Forum 2 07-04-2005 00:33
Pneumatic Wheels Steve P Pneumatics 4 07-02-2005 15:16
Pneumatic Gripper ruling Nitroxextreme Pneumatics 7 30-01-2005 13:04
Who has used pneumatic wheels? chellyzee93 Kit & Additional Hardware 3 16-02-2003 11:49
