Go to Post a determined team can accomplish miracles. - Wayne C. [more]
Unread 11-01-2006, 01:23
Nathan Pell's Avatar
Nathan Pell Nathan Pell is offline
FRC #0233 (The Pink Alliance)
Nathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to behold
Re: Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance
Originally Posted by Ethulin
We already have something to base the air friction on, FIRST told us that it will travel 35feet at 30 degrees. That is WITH air resistance. We should be able to base our calculations off that.
The 35ft at 30 degrees is with no spin, so we can do some tests with spin afterwards, but lets get the basics first, i.e. without spin.
Just curious.. where did you find this?
Florida First
Unread 11-01-2006, 01:37
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Taken from Section 4 - The Game
<S02> Muzzle Velocity - No ROBOT may throw a ball with an exit velocity of greater than 12 m/s (26.8 mph).
As a reference, a ball traveling at this velocity when leaving the ROBOT at an angle of 30º from
horizontal with no spin will travel approximately 35 feet. A robot that violates this rule will be
considered unsafe per <S01>.
Unread 11-01-2006, 01:40
Originally Posted by Bill Moore
Has anyone done weight checks to determine the the population range and median?
And the mean, mode and standard deviation? I also want to see a scatter plot to check to see if it is a one-tail or two-tail population, or even one with more than one mode. Some sort of 3D modelling of mass density would be nice, too.
Unread 11-01-2006, 01:42
I massed 6, using a mean of .18 ... the mass deviations dont significantly affect the range..
Unread 11-01-2006, 01:48
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
Originally Posted by Tatsu
Not sure what I'd need.. I just need someone with Mathematica 5.1 that can execute my notebook.. if not I'll just have to run it overnight or something.. not that big of a problem.
Tatsu.
Anyway, the equation isn't that bad if you dont try to make it a diffeq problem.. its just small timestep modeling.. and yes, you probably cant do this by hand (and thus the RC wouldnt be able to either.)
so if you want accurate trajectories, you'll need lookup tables.. (I cant think of any other way to calculate air resistance trajectories on the fly..)
When I posted this all I wanted was that distance. So we can make a "no one can shoot past here arc" on our field.
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 11-01-2006, 01:56
oh, is THAT what you want?
I think that's 6.5 meters. well, I'll just generate the full table and find the max, faster that way =p.
*edit* - wow, finals studying is making me drowsy.. but the max should be around 8.8 meters.. give or take maybe .5 meters.. (sorry, I dont have a full lookup table, but this seems pretty close..)
*edit 2* - does anyone still want the lookup tables?
Unread 11-01-2006, 02:28
AKA: Erik Thulin
I might if I knew what they were... all I know that I need is that one length, what will that table give me?
Also, is there any way to calculate what the best angle would be instead of 45 degrees?
Unread 11-01-2006, 02:48
Well, a standard lookuptable is something like this..
y axis - theta
x axis - v
the entry for some v and theta gives you the distance (in this case from 5 ft to 81/2 ft).. therefore you reverse-lookup to find a theta. Lets say you keep v constant at 12 m/s Now just find an entry in the table which is equal do your distance from the goal... that gives you your fireing angle. Fire.
Otherwise you have to calculate angle depending on your distance, that's not possible when you factor air resistance.. (at least not to my knowelege).. so you have 2 options
a). use lookup tables to find an angle that matches your distance
or b). use a model without air-resistance and be off by a large amount the farther away you get.
Either way its not pretty, but I think our team wants to do a). (psst.. dont tell them I already made the lookup table, I want to see how fast our programmers get it =p )
Unread 11-01-2006, 14:22
AKA: Erik Thulin
LoL! So mean... so mean....
Unread 11-01-2006, 14:44
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here is a picture that show a theoretical max distance. It ignores the effects of drag and spin.
It shows the theoretical max distance, when the ball is launched from ground level, at 12m/s and 45 deg. elevation to be about 37.2 ft/11.34m.
Unread 11-01-2006, 17:05
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
In another thread, I posted a link to a paper that describes how to calculate the trajectory of a ball, including air resistance. I also attached an Excel file that allows the user to vary launch speed, angle and height as well as ball mass, diameter, drag coefficent. It produces a trajectory plot with the upper and lower heights for the goal shown on the graph. It's pretty easy to use and gives you a tool to determine how sensitive the trajectory is to the various parameters.
See:
http://www.chiefdelphi.com/forums/sh...710#post429710
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 11-01-2006, 18:12
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Im no math whiz, but would this work? have your launcher (for instance turret like a snowblower) and mount the cam so its on the top of the launcher, then proportionally program the offset of cam-turret to greenlight-hole? that way when your bot drives the cam always tracks the greenlight and your launcher is always aimed there. Me=mechanical and not too electrically intuitive, is this possible?
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 11-01-2006, 19:51
obitusis obitusis is offline
obitusis is an unknown quantity at this point
By the way billbo911's calculations were provided by:
www.hyperphysics.phy-astr.gsu.edu
We got:
From 1.4 meters off ground to center of goal, we calculated that max range 11.1 meters at 48 degrees. That includes drag coefficient of 0.3 - constant drag coefficient. The proof is left for an exercise for the reader.
Unread 11-01-2006, 20:09
How'd you get that number? you're off about 3 meters from my calculations.. weird. want to run your caclulations again with a coefficient of .416 (should be more accurate)? I might be wrong..
Unread 11-01-2006, 20:34
Mirza95vx Mirza95vx is offline
The BOSNIAN
AKA: Mirza Strujo
None #1511 (Rolling Thunder)
Mirza95vx is a jewel in the roughMirza95vx is a jewel in the roughMirza95vx is a jewel in the roughMirza95vx is a jewel in the rough
Send a message via AIM to Mirza95vx
Air resistance is not a factor unless you are going 75+ mph. So you dont have to account air resistance into the equation.
Rolling Thunder 1511 Beware of the THUNDER
2005 Rookie All-Star Award-- FLRC,
Quarter Finalists-- FLRC,
Semi Finalists-- Buckeye,
Highest Rookie Seed-- Buckeye,
Team Spirit-- GTR,
Rookie Inspiration-- GTR,
Highest International Score 128-0--GTR
Greater Toronto Regional Winners-- Thanks to 1114 and 1305
Congratulations to Kim Otoole for winning the M&M Excellence Award
SO FAR SO GOOD
27-12-2 FLRC & Buckeye & GTR
Rolling Thunder
