Go to Post Woody, If there is any chance your reading this ... you've changed my life. - Gope [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 11-01-2006, 09:20
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: WinXp Registry error during install
Thanks Danny!
...looks like I get to play with regedit. I'll try it out tonight.
Eric
Don't PANIC!
S. P. A. M.
Unread 15-01-2006, 22:42
FRC #0180 (SPAM)
OK! ...part way there. Over the weekend we successfully loaded LabView8 and the Device Drivers on 2 student laptops and a Team desktop. Then, after following through with Danny's suggestion I was able to make a change in the registry, and load LabView 8 on my laptop. However, when I tried to install the Device Driver CD #1, I got this error from setup.exe:
The instruction at 0x%08lx referenced memory at 0x%08lx. The required data was not placed in memory because of an I/O error status at 08%08lx.
A quick search of 08%08lx on the NI forum pages revealed a similar problem with someone trying to load VISA. But the suggestion was to download a new version of VISA. That doesn't particularly relate to reading the CD...?
Anyone else encounter this?
Eric
Don't PANIC!
S. P. A. M.
Unread 17-01-2006, 09:33
AngelaM AngelaM is offline
AngelaM is an unknown quantity at this point
Eric
Are you trying to install directly from the CD? Or are you copying the contents of the CD to the hard drive and installing from there? If you are installing from the CD right now, I would try installing from the hard drive.
Unread 17-01-2006, 10:42
FRC #0180 (SPAM)
Originally Posted by AngelaM
Are you trying to install directly from the CD?...
I was trying to install directly from the CD. I'll try copying the contents to my HD and go from there.
Thanks!
Eric
Don't PANIC!
S. P. A. M.
Unread 17-01-2006, 13:21
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Also realize we've gotten numerous reports of issues with some types of CD-ROM drives reading the Driver CD - it could be due to a bad batch of CDs from our duplication center, teams who have attempted to bit-copy the CDs have had miserable results which could point to bad disks.
Installation of the Driver CD is not required - the Driver CDs contain a lot of drivers that US-FIRST teams don't need unless you've got an NI-Scope or NI-Motion controller laying around, for example. Most teams only need to install LabVIEW and NI-VISA, while NI Pilot Program teams need the additional download of NI-DAQmx.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 18-01-2006, 01:41
AKA: Dr. Brooks
no team (WRRF)
-Danny
Is NI-VISA installed by the Labview 8 installation, or do we need to download and install it from the net? If we must download it from the net, which version should we get for Windows XP Pro? There are more versions at this http link than you can shake a stick at...
Unread 18-01-2006, 08:52
From the ni.com home page you can select Drivers and Update>> Current Versions which brings you to this page
http://digital.ni.com/softlib.nsf/we...de =132060_US
From here you can find the most current driver versions. You can find NI-VISA under Instrument Connectivity. There you can find the driver for your operating system. Or the following link has the most current driver for Windows XP
If you need DAQmx from the first link you can find Multifunction DAQ under Measurement Hardware. The following link has NI-DAQmx 8.0 for Windows 2000/NT/XP
Unread 18-01-2006, 11:43
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
If you're looking for a smaller download on the PC, or you're looking to install for a Mac, NI-DAQmx Base also provides the base functionality needed to use the NI USB-6009 DAQ device. If you have other DAQ devices from National Instruments, the DAQmx Full Edition may be required to use the device; check the readme file to determine if your device is supported under DAQmx Base.
-Danny
Danny Diaz
Unread 18-01-2006, 11:31
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Depends on what OS you're running on.
If you're on the PC (Windows variants) the LabVIEW 8.0 installation does NOT install NI-VISA; for PC, the model we adhere to involves installing the Driver CD which includes NI-VISA (or install NI-VISA seperately). The Driver CD contains all of the Windows drivers you would ever need for all of our products, so if you don't want (or can't) install the Driver CD you can seperately download the components you need to speed installation (turn off your virus scanner for faster installs!).
If you're on the Mac, LabVIEW 8.0 DOES install NI-VISA because the Mac does not have a Driver CD.
-Danny
Danny Diaz
MplaB 5.70 won't install soundman Programming 4 08-01-2005 23:02
phpBB 2.0.10 install Ryan M. Website Design/Showcase 2 18-11-2004 19:21
