Go to Post When twenty people tell you your hair is on fire, you don't need to look into a mirror to find out they're right. - IndySam [more]
Unread 11-01-2006, 09:55
firstborn firstborn is offline
Team President
AKA: LiSeR
FRC #0842 (Falcon Robotics)
firstborn is an unknown quantity at this point
Send a message via MSN to firstborn
Platform Surface
will the top of the ramps be made out of lexan or the other plastic stuff?
·¨*·.¸¸.*Annalisa*.¸¸.·*¨·
Unread 11-01-2006, 10:17
Re: lexan or something else?
Read the manual.
Originally Posted by 3.2.4 Alliance Platform
An Alliance Platform is located at each end of the field adjacent to the Alliance Station Wall. The horizontal surface of the platform is 12 inches above the field, 48 inches deep, and 11 feet wide. The surface of the platform is covered by clear polycarbonate. An aluminum diamond-plate ramp leads up from floor level to the top of the platform at a 30-degree angle. 24-inch tall walls made of 1/2 inch polycarbonate form the ends of the platform to prevent robots from falling off the platform.
Unread 11-01-2006, 10:42
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Alan Anderson
Read the manual.
And FYI, Lexan is GE's trademark for polycarb.
Joe J.
Team #88, TJ2
Ramp and Platform model problem. Jay Trzaskos Inventor 1 08-01-2006 02:13
Surface mount components [527]phil Electrical 9 07-01-2006 20:24
POLL: What surface do you want to see? Rombus FRC Game Design 46 13-04-2005 15:03
Dimension Wanted - BOM Caster: floor to top plate surface height kmcclary Kit & Additional Hardware 2 28-01-2004 12:02
Extra ramp and platform outside the field at each event to test and practice? Digo General Forum 4 19-01-2003 21:39
