Go to Post Proof: Remove the motor from it's mechanical house of bondage and it will operate just fine - Mike Betts [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-01-2006, 09:56
BlazinFire47's Avatar
Happy Birthday! BlazinFire47 BlazinFire47 is offline
Alumni
AKA: Blaze/Blackmoon/Nova
FRC #0047 (Chief Delphi)
BlazinFire47 is on a distinguished road
Send a message via AIM to BlazinFire47 Send a message via MSN to BlazinFire47 Send a message via Yahoo to BlazinFire47
Re: Green Light Power Source
why not just use a 12 volt battery that you use on your robot to power it? it seems very easy to do to me. wire them all together, or on a disto-block, and put a switch on it somewhere and power it like that. itll be like wiring them to your car,pc, robot cart, or whatnot.
Unread 11-01-2006, 10:08
One of those jump-start batteries sold in auto parts store would work great, to, if you already have one. Many of them also have 120 VAC inverters built in, which could come in handy at the tournaments, too, especially if you want a stereo on your cart... (just don't bring a music cart to Portland, please).
Unread 11-01-2006, 11:00
Windwarrior Windwarrior is offline
AKA: Scott Davis
FRC #1777 (Viking Robotics Club)
Windwarrior is an unknown quantity at this point
Anyone thought about using the power source from an outdoor lighting set-up? They are 12 v. and can be plugged in to a wall socket which never get discharged!!
Just an idea!!
Unread 11-01-2006, 12:20
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Just an idea!!
I think Outdoor lighting may be 12v AC (Alternating Current) in which case it will not work.
Unread 20-01-2006, 14:44
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
you could use the ATX computer power supply or get an older computer(p1 or p2) and get the switching power supply out of that it will usually supply around 4 amps which is enough and the switch will turn it on/off so there is no shorting out pins.
KK4KQO
http://voltair.us
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
program light blinks red and green JBabbie Programming 3 02-03-2004 09:19
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
