Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Unread 11-01-2006, 12:54
Re: CMU code can't find stdio.h
You are missing the include file path in your project. It sometimes gets dropped when a project is moved to a new machine or when a new project is created.
In MPLAB
Project -> Build Options -> Project
In the pop-up window look for "Include Path" and set it to
C:\mcc18\h
(or for those of you who didn't use the default install directory for the compile, then browse to wherever it is)
Code Structure, Organization, Division of Labor! dm0ney Programming 3 28-03-2005 23:08
Problem downloading any Camera code zuckie13 Programming 4 07-02-2005 20:32
Pwm 11, 12 and CMU code Chris Bright Programming 3 01-02-2005 19:34
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
