Go to Post If by hazardous you mean thinking about robots 24/7, waking up at 2am in the morning to jot some ideas down, completely losing your social life, and staring at a computer until your eyes hurt, then yeah! :D - looneylin [more]
Unread 11-01-2006, 14:51
XtremeEagle04's Avatar
XtremeEagle04 XtremeEagle04 is offline
AKA: Jon
#0326 (XtremeEagles)
XtremeEagle04 is on a distinguished road
Send a message via AIM to XtremeEagle04
Diffuser Panel Problems
We have been trying to get the camera to see the diffused green light source and it keeps washing out. even when we turn out the lights in our robotics lab, the camera can't see the green light. any suggestions?
Think it....
Design it....
Build it....
Unread 11-01-2006, 21:28
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Diffuser Panel Problems
Did you follow the instructions in the CMU camera guide, where you download a .ZIP file from national instruments and upload a .CFG file to the camera?
If not, then do that.
Our camera also did not see the green light, just a lot of everything else. Default configuration is to see all colors equally - correct for a normal camera. The file "2006 CMUcam.cfg" parameters are correct for the green light. (Or, at least, very close to correct. Yours may still need some tweaking)
Don
Unread 11-01-2006, 21:55
Andrew Blair's Avatar
FRC #0306 (CRT)
Haven't done it yet, but accoding to Kevin's CMUCam everything you need to know, it says you need to properly calibrate the camera's exposure so that it sees less light and more color. I think that if you move the target farther away, you'll get more color. They're really bright so that you can track them from across the field, potentially.
-Sir Francis Bacon
-Albert Einstein
Unread 12-01-2006, 16:19
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
We followed the guide and had no problems. Make sure your target is getting 12 volts (so the lights are bright enough), make sure all the cold cathodes are on, and it helps if it is built of a reflective material. Our camera picked up the target with no problem from about 4 meters away.
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Vanilla ice cream == car problems?? Ken Leung General Forum 16 22-11-2005 11:07
Need Your Input - Is my OI panel still legal? CraigB Rules/Strategy 12 25-04-2005 22:55
Bad Breaker Panel? jdiwnab Electrical 5 14-02-2005 14:45
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
