Go to Post You can learn a lot from making mistakes - even more from fixing them. - DarrinMunter [more]
Unread 11-01-2006, 14:49
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
4WD, is it legal?
Does anybody knows whether if 4 wheel drive is legal?
I need it ASAP, our engineer is here...
Thanks & Good luck!
Unread 11-01-2006, 14:54
mpob's Avatar
mpob mpob is offline
AKA: Mike OBrien
#1511 (Rolling Thunder)
mpob will become famous soon enoughmpob will become famous soon enough
Re: 4WD, is it legal?
Thanks & Good luck!
Sure it is,
you can have 1, 2, 3, or 4 wheel drive, or even more!
Good luck in your design!
--Mike
Roll Strong!
Mentor Team 1511 - Rolling Thunder!
Unread 11-01-2006, 14:57
Thanks,
Can we put 2 engines for each side (total 4)?
Thanks!
Unread 11-01-2006, 15:02
REVving up for a new season
FRC #2848 (All-sparks)
sure can, you can use whatever motors in the kit you want in whatever configuration your mind can imagine.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
in between teams
AKA: Luke Van Oort
Yes, you can. The kit transmission is designed to be able to do this. In past years, teams have done two, four, and six motor drivetrains. With this kit you could even do eight with some fabrication. There is a white paper about the common drivetrain designs in the technical section that you might want to read.
Team 1219: 2009 - Mentor
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Yes. The gearbox instructionmanual found on IFI site will demonstrate one way to do it.
http://www.ifirobotics.com/kitbot.shtml
Unread 11-01-2006, 17:30
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Check out the picture gallerys of past robots. You can get a lot of good drive train ideas from there. As far as motors go you can put as many as you want per side but just make sure that you have enough motors to do other things on the robot and that you don't overload the main or the smaller circuit breakers. Also there are certain design issues with some of the different motors that have to be looked at. Read the different threads on here. Theres a good one about the Fisher-Price motors thats informative for rookie teams.
Good luck
~Kirk
Unread 11-01-2006, 17:38
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
In general, you can do whatever you like in the construction of FIRST robots. The main rules, the ones that anyone designing the robot will need to know by heart, are:
  • weight limits
  • size limits
  • only allowed motors are those in the kit (plus two more CIMs)
  • electrical system except for sensors is mostly restricted to whats in the kit
  • only allowed pneumatic stuff is either in the kit or orderable from a short list of places. (except for trivial stuff like hose, etc)
  • price limit
  • and, of course, generally safe designs are required.
That's really it. You are pretty much free to do anything within those rules.
Team 1257
Capping a Team Legal? Nate Edwards General Forum 36 28-02-2005 21:33
Is it legal to change pit locations ? capof541 General Forum 9 24-02-2005 12:36
gas shocks legal? ajlapp Rules/Strategy 3 01-02-2003 22:42
Are these mat'ls legal? archiver 2000 1 24-06-2002 00:15
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
