Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 11-01-2006, 09:47
Ami Schwartz Ami Schwartz is offline
FRC #1657
Ami Schwartz is an unknown quantity at this point
Q. about "the ball"
Hi, did anyone see a rule about 'ball hiding" in the match ?
( i mean did you see a rule that says you are not allwoed to move the ball inside the robot that it is not visible to the eye)
mods, if i post this in the wrong place please move it
Thx Ami.
Unread 11-01-2006, 10:15
Re: Q. about "the ball"
I think this is what you're referring to.
Originally Posted by <G13>
Balls Contained in ROBOTs at the Start of a match - Each ALLIANCE will start a match with 40 balls. Each ROBOT may contain up to 10 balls at the start of a match. Any balls not contained within the robot will be evenly distributed between the alliance ball corrals. All of the balls must be contained within the ROBOT’s 28” x 38” x 60” starting volume and must be clearly visible from outside the ROBOT. The Head Referee will require that balls outside of the starting volume be removed. It is the responsibility of the head referee to verify that this rule is satisfied prior to the start of the match.
I don't see any rules about the visibility of balls entering the robot after the start of the match.
Unread 11-01-2006, 12:24
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video &quot;wizard&quot;
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Hmmmm.
let's see. If you draw black curtains around your ball storage compartment DURING a match, what does it prove?
Well, the opposing alliance won't know just how much ammunition you've got on-board, so that may alter which 'bot they want to thrust their defense against.
On the other hand, a ball that is stored or hidden in your robot is not a scored ball, therefore, it's s moot point to hide balls?
Interesting discussion here.......
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 11-01-2006, 12:56
Ashley Christine's Avatar
Ashley Christine Ashley Christine is offline
FRC #1511
Ashley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond repute
I am sure that if they want the balls to be seen then they will make a revision to the rules.
Besides that, I dont see why you woudnt be allowed to, it says "Robot starting" not "Robot playing"
Its another one of those judgement things... I am sure FIRST will clarify at some point if they realize they meant it differently.
Like Doug said, the other alliance wouldnt know how many balls you have, which could be scary when trying to decide when and where to score your own balls! But also as he said, just because you have them, it doesnt mean you will get any of those points. You could have an awesome storage system but no way to get the balls out!!! xD I hope that wouldnt happen, but you get the idea.
Unread 11-01-2006, 16:38
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Just a note if you hide the balls from your opponents you'll also end up hiding them from yourself. I know that the drivers should have a better idea of how many balls they have than the opponents who have their own robots to drive, but in the heat of the moment I think its more usefull if you know how many balls you have and giving up the advantage of secrecy.
Perhaps covering just the front side of your robot with a curtain wouldn't be such a bad idea, since it would stop the other team from seeing your balls when you're pointed towards them which is when they might care most. It might even be legal to start with a curtain on one side so that the balls are visible from other angles.
Team Website
Unread 11-01-2006, 16:45
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
If your opponents are good enough it doesn't matter if you hide balls because they al recirculate anyways.
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
It would be interesting if you had: one robot that could shoot, one that emptied balls into the corner goals. They have curtains to hide the balls, they come together and do an exchange(or not) of balls. They then rush to the goals, and the defenders have no clue which bot has all the balls! an in game trick show. haha =)
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
Unread 11-01-2006, 17:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
As I interpretted from my father's response when I mentioned this rule to him in reference to the red "shooter" bot and how I beleived it violated this rule, he reponded that you could see the balls by looking down the barrel of the "gun". So, unless your opponent has the time to look down your barrel and count the balls....
(note that this also implies that you can see how many balls are visable, not just the top one)
Unread 15-01-2006, 02:43
FRC #1657
I see, but may i put our balls in a galss tube ?
then they are visible.
(or not glass just transparent) .
Unread 15-01-2006, 03:31
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
My interpretation of the “must be clearly visible from outside” was not in the area of strategy but to allow the referees to count each bot and to make sure that no more than 10 poof-balls are in any bots before the start of a match.
This rule prevent alliances from packing good shooter-bots full of balls.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 15-01-2006, 08:53
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Thx Ami.
This will work exactly once against teams that scout properly. After that, your average number of balls collected/average number of balls shot/average number of balls scored will be known. As the qualifying rounds continue, they will establish the "maximum number of balls collected". These facts will determine how aggressive the defense would play against your robot.
Team scouts will also have data on the mechanical condition of your robot, from "needs a jump start" to "flys like the wind".
You can only surprise teams once with most strategies, then you have to figure out what the next step is when they react to the first strategy.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Finding Coordinates of "The Blob" Jatheon4316 Programming 4 30-06-2005 10:45
"The Sims" - Does any one of the expansion packs cover these features? Elgin Clock Chit-Chat 2 26-06-2004 01:37
pic: Team 311's Robot ("The Claw") CD47-Bot Robot Showcase 2 26-02-2004 19:15
"The Slim Fast Robot" archiver 2001 7 24-06-2002 00:55
