Go to Post Is it bad when are you just sitting at home wishing KICKOFF was here. - JulieB [more]
Unread 10-01-2006, 19:02
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
Parabola
First time I need to use an actual parabola (not those curved lines that sometimes look like parabolas) in inventor for simulation of projectile launching in 2D sketch, but I can't find the tool, not even in the help topics (I hope it exists). Does anybody knows how to make it?
thanks
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 10-01-2006, 21:14
Ebolagirl's Avatar
Ebolagirl Ebolagirl is offline
I <3 Inventor!!!
AKA: Tracey
FRC #0418 (Purple Haze/LASA Robotics)
Ebolagirl has a spectacular aura aboutEbolagirl has a spectacular aura aboutEbolagirl has a spectacular aura about
Send a message via AIM to Ebolagirl
Re: Parabola
Hmm... I'm not quite sure what you're trying to accomplish and I don't have Inventor in front of me right now so I can't mess with it. But it sounds like the splines didn't work for you? Try a the three point circle thing. That may work. It's in the circles section.
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot."
-Someone
My other passion... http://www.cdc.gov/ncidod/dvrd/spb/m...s/ebola/qa.htm
Isn't it adorable?
http://www.giantmicrobes.com/calamities/ebola.html
Unread 10-01-2006, 21:22
Daniel_H's Avatar
Re: Parabola
I used splines and tried to get as close as I could of a parabola, it worked as I needed (even that I had to calculate some reference points in my notebook), but since inventor has so many tools, I thought it would have at least one easy way to get a parabolic shape curve.
Thank you anyway
[<o>] gogogo [<o>]
Unread 10-01-2006, 22:46
Ebolagirl's Avatar
I <3 Inventor!!!
AKA: Tracey
Re: Parabola
Sorry that's the best I could do for you... I've never had to use a parabola shape either. And hopefully I never will... hehe.
-Someone
Isn't it adorable?
Unread 10-01-2006, 23:25
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Parabola
I believe splines are actually cubic functions so in theory they should be able to approximate a parabola pretty precisely. That doesn't mean its easy to drag it into a correct shape. Just a note, You can also import a parabola graph/image from somewhere else and draw the spline ontop of it to match the image. Best I can offer as well.
Team Website
Unread 11-01-2006, 13:23
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
Re: Parabola
i have an idea.
calculate where you would want the endpoints of the parabola to be. find the distance between them. set the two endpoints of the spline to that distance. then find the distance between the mininimum, going straight up, to where the endpoints would be. then set that distance, and make the minimum of the spline halfway between the two end points. im not sure if this will work, but i think it would be pretty close.
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 11-01-2006, 16:20
Daniel_H's Avatar
Re: Parabola
Originally Posted by CmptrGk
i have an idea.
exactly what I did, plus I also put the start tangent to a line with the angle of my shot. It looks like a parabola but I'm not sure it is one. Well it works fine for projectiles anyway
[<o>] gogogo [<o>]
Unread 11-01-2006, 18:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Parabola
I'm thinking there should be a way to make a line follow an equation. I'm wondering if you could do some fancy work with parameters to make it happen. If anyone knows, I bet'd be DanielBCR. Maybe he'll stumble upon this thread.
Unread 11-01-2006, 18:49
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Parabola
I do not yet have autodesk readily availible to mean right now but can you enter equations into the precise input boxes?
Unread 11-01-2006, 19:04
Re: Parabola
I believe the answer to that is yes, but I also believe it would just solve the equation rather than plotting it.
I'm not sure exactly what you are trying to do but perhaps something like Excel would be a better tool of choice?
Unread 15-01-2006, 17:28
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Parabola
I don't know much Inventor, but I do know that parabolas are conic sections...can you make a cone and use the intersection between the cone and a plane?
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Did you ever wonder what it would be like to pop a water balloon in space? Brandon Martus Math and Science 14 29-03-2004 18:55
