Go to Post If you're doing it to win, you're doing it wrong. Teams who truly understand why they are doing what they do will win Chairman's simply as a result, an added benefit. The award isn't the goal. It's the impact you create, and the results you see. - dcarr [more]
Unread 11-01-2006, 21:25
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Trig functions and type conversion
I'm trying to use the CORDIC function to do some basic trig (calculating an angle given an x and y coordinate from a joystick), and I'm getting some odd results.
In short, if I calculate the angle using the atan() function, the results work when y>0, but give incorrect and discontinous results if y<0.
Here's the simplest code that I came up with the recreates the problem:
#include "cordic-math.h" // renamed so that I know it's not the Microchip one
short long joyx,joyy;
short long theta;
joyx=(255-p1_x)-127;
joyy=p1_y-127;
theta=atan(joyy,joyx);
printf("theta: %d ",(int)(theta>>16));
Anyone have some thoughts? I at first thought it was a problem with negative numbers and the >> operator, but theta/65536 gives the same
numbers.
Unread 12-01-2006, 10:34
Re: Trig functions and type conversion
That's just the nature of arc tangents. You need to determine which quadrant you're in and offset the answer accordingly. Some trig libraries provide an atan2() function that deals with the issue for you.
Unread 12-01-2006, 10:57
kaszeta's Avatar
Hmmm, I assumed since the CORDIC library atan function took two arguments it was an atan2 function, but it appears I assumed incorrectly. Thanks.
Unread 12-01-2006, 17:40
TechnocratiK TechnocratiK is offline
AKA: Patrick Diez
None #0296 (Northern Knights)
TechnocratiK is an unknown quantity at this point
Did you write the library, or get it somewhere?
TechnocratiK out.
Unread 14-01-2006, 16:40
p1r0o2g7 p1r0o2g7 is offline
p1r0o2g7 is an unknown quantity at this point
why don't you use the math.h header. i'm pretty sure it has all the trig functions.
http://www.cplusplus.com/ref/cmath/
Unread 14-01-2006, 17:22
kaszeta's Avatar
It's the CORDIC library from the Whitepapers section here on CD. You can get it here
I was trying to use it instead of the standard math.h since it uses integer math instead of floating point, so it's much faster (and smaller).
For now, I'm using the standard math.h, but if our team's code gets too complicated, I might revisit this.
Unread 14-01-2006, 23:34
AKA: Patrick Diez
OK, although my good friend Pat Fairbank posted the algorithm, I wrote it, and can assure you that there is a flaw in it (although I haven't had the time to look at it). Moreover, although theoretically the integer math should be faster, in empirical tests, the stock math library proved to be about 6 times faster than the CORDIC algorithm I wrote. Although at the moment I have no plans to rewrite the CORDIC algorithm, given enough public pressure, I might consider doing so. Sorry for the inconvenience.
TechnocratiK out.
Auton + Functions ten3brousone Programming 0 27-02-2005 20:11
Overloaded functions jgannon Programming 5 31-12-2004 11:04
