Go to Post It takes a special kind of lunatic to be the school sponsor/mentor for an FRC team; when you get one be thankful. - Fusion_Clint [more]
Unread 11-01-2006, 05:58
Phil Paspalas Phil Paspalas is offline
FRC #1676 (The Pascack Pioneers)
Phil Paspalas is an unknown quantity at this point
Working with Lexan
Last season, our team used Lexan (polycarbonate) to shield the electronics from damage. We found it easy to cut, bend, de-bur, and generally pretty good stuff! But it's a pain to drill!!!!!!!!!!!!! Especially when trying to drill large holes in it to remove weight. We tryed a hole saw with poor results and regular twist drills were problematic as they get past 3/4". Any suggestions?
Phil Paspalas
Head Coach - Team 1676
2005 NJ Rookie All-Stars
Unread 11-01-2006, 06:33
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
Re: Working with Lexan
try lubricating the drill bit with dish soap, it generally produces good results
http://www.wcsrobotics.com
team 663
team 1493
Unread 11-01-2006, 10:07
RoboGeek RoboGeek is offline
AKA: Matt Kinnison
#0063 (The Red Barons)
RoboGeek is an unknown quantity at this point
Send a message via Yahoo to RoboGeek
go pick up a set of step drills and use them they will make life alot easier! I suppose it is possile to just use 5 different bits in and step up through them but a step drill will be alot faster and a sharp one will go through lexan like a hot knife through butter! in '04 I personally drilled almost 6000 3/4" holes in sheets of lexan for our bot (we didn't use them as they were still too heavy and if we drilled anymore holes we wouldn't have a side panel lol!!)seriously though get a set and go at it its faster then you think and quite easy!
Unread 11-01-2006, 11:22
REVving up for a new season
FRC #2848 (All-sparks)
The problem with working with lexan and any other plastics is that they tend to melt before the bit actually chips away at the material. An easy solution for cutting plastics is to turn the drill bit or hole saw slower, this makes less heat and there is less of a likely hood of melting. Alot of lubrication on the bit and material will help as well.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 11-01-2006, 13:23
TheAnsweris42's Avatar
TheAnsweris42 TheAnsweris42 is offline
Team 1896 "Rules Guru"
AKA: Kenneth Casperson
FRC #1896 (Xodus)
Team Role: Webmaster
TheAnsweris42 will become famous soon enoughTheAnsweris42 will become famous soon enough
Send a message via ICQ to TheAnsweris42 Send a message via AIM to TheAnsweris42 Send a message via MSN to TheAnsweris42 Send a message via Yahoo to TheAnsweris42
So, in your opinion, would lexan or another polycarb be a good choice for the outer shell as well? Some of us think we might want to try and do something like that, because it would make the visibility requirements on the controller and ball bin a lot easier, and would make good protection. We're a rookie team, though, and since we don't have any experience in how rough things might actually get, or how much the polycarb would cost...
"A common mistake people make when attempting to engineer something completely foolproof is to underestimate the ingenuity of complete fools"
-Douglas Nathaniel Adams
Unread 11-01-2006, 13:46
As a rule of thumb about lexan/polycarbonate:
load bearing or going to take hits 1/8" or larger
non load bearing plates for numbers and such 1/8" or smaller.
The uses of lexan in FIRST basically come down to how flexible you can accept during use because even with the forces involved in robot collisions i have seen very little polycarbonate break. So the thicker it is the less flexibility you have and vice versa....Plexiglas is another story all together.
Unread 11-01-2006, 13:50
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Poly Carb is great for protective panels. If you have supports under it you can go as thin as 1/16" which is what we usually use. Poly Carb is very good for resisting puncture and will not crack. One warning MAKE SURE YOU GET POLY CARB most stores will sell acrylic as poly carbonate. Acrylic is not only not allowed in first but is breaks like glass when it is impacted or bent.
Good luck on your rookie year and feel free to post up if you have questions about anything.
~Kirk
Unread 11-01-2006, 13:52
not true anymore..the restrictions on acrylic and plexi were lifted last year.
Unread 11-01-2006, 14:09
Electrical Engineer
Rookie Year: 1995
For safety reasons, I would never allow plexiglass on a robot. Polycarb only. IMHO, FIRST is making a mistake in allowing plexi...
The "step" drill referred to above is usually called an omni-bit. Omni-bit may be a trade name but any hardware store will know what you are looking for. It drills through polycarb like butter.
Mike Betts
As easy as 355/113...
Unread 11-01-2006, 14:11
I agree whole heartly with you i think they did this because sometimes teams only have access to specific materials and plexi is still more common and cheaper then lexan/polycarbonate.
Unread 11-01-2006, 15:03
FRC #0254
For those teams that don't know how to tell the difference between the two, the best way to tell is take a pair of pliers and try to bend a corner. If it bends like a piece of soft aluminum its polycarbonate if it cracks or breaks its acrylic.
~Kirk
Unread 11-01-2006, 15:09
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
~Kirk
There is nothing like Brute Force Testing to come to a very quick answer.
Unread 11-01-2006, 16:27
FRC #0254
Other wise its pretty hard to tell them apart if the wraping has been removed.
Unread 11-01-2006, 17:18
FRC #1896 (Xodus)
Alright, awesome. Thanks for the advice, did I mention you guys are the best? lol... I'll be showing up now and again, count on it
Unread 11-01-2006, 23:09
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Yet another way (and probably the easiest) is to look at the edge of the sheet of plastic.
White or frosted transparent: Acrylic (plexiglas)
Blue frosted: polycarbonate
From what I recall, polycarbonate has a "blueness index". The higher the number, the more blue tint it has. Since 1963, when Dan Fox at GE invented LEXAN, this "blueness index" has gotten lower and lower.
Andy B.
Sources for Delrin and Lexan stock sanddrag Technical Discussion 3 04-12-2005 00:25
Who is working on their team site over the summer? Timothy D. Ginn Website Design/Showcase 15 07-06-2005 18:47
IR Beacon/reciever not working... still... Ferazel2001 Programming 23 04-02-2004 23:30
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
Whose working this summer? Frank(Aflak) Chit-Chat 20 28-05-2003 11:35
