Go to Post Unfortunately our team missed out on a great opportunity to "learn from the pros" because we did student-centric things like insisting on having a student field coach. - Tom Bottiglieri [more]
Unread 11-01-2006, 23:57
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Calculating Angle to fire at
Originally Posted by seanwitte
Theres nothing wrong with that approach, but time is a finite resource and it is not the hardest problem here. It seems to me there are two very difficult problems involved:
1) Build a contraption that consistently shoots the balls at roughly the same speed (and hopefully direction!)
2) Build a gimbal mount that can be quickly and accurately positioned to control the launch angle for the gizmo in part 1.
I think part 2 will be the deal breaker for most teams. Moving an appendage is one thing, but this requires tight tolerances to make it work.
The KISS rule probably applies here (as in most things in life).
You need to understand the relative complexity of items #1 (consistent speed) vs. #2 (agile and accurate gimbal mechanism) and factor in the relative importance of 1 vs. 2. It seems to me that unless you plan to alter the launch angle based on the launch velocity on the current shot, #2 is not very important. If you shoot the ball at fixed angle and consistent speed, you should be able to deliver the ball in the proper height over a rather large range from the goal. I think that's the key in this game.
Hint: play around with the Excel spreadsheet I posted earlier in this thread, now attached below with a minor correction. I now divide by 8 in the drag factor parameter instead of multiplying by 0.128 (obviously I meant to multiply 0.125 in the original version...2% error - my bad!)
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Last edited by David Brinza : 12-01-2006 at 00:13. Reason: Attached revised Excel spreadsheet
Viewing Angle of Camera Joe Johnson Technical Discussion 10 14-01-2005 14:11
Calc. Triangle Angle or Side Based on Ellipses? indieFan Math and Science 1 07-06-2004 21:25
Serious VCU Fire Joe Matt Chit-Chat 3 26-03-2004 19:04
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
